Posts: 1,451 |
One of my co-workers just came in complaining about her radio not working so I took a look. I'm stumped so maybe you guys can offer some advice. Setup is a sony HU, factory speakers, external amp running some subs. Cd player plays fine and AM radio plays fine. However, no sound at all through FM stations, not even static. She said it happened yesterday out of the blue and hasn't come back on. The only conclusion I can come to is that the FM on the HU is toast and she probably needs a new one. I tried resetting the HU but no luck. Any of you guys ever hear of this happening as I've never experienced this before. Thanks for any input.
Vinny 2000 T-RED CSVT
MODS: 18" REV model 2 ST200 struts/Roush springs
CTA intake Pipe/K&N Filter
Dtec Heatshield
Optimized TB
True Duals w/ magnaflow mufflers/resonators
Posts: 1,279 |
How did you try to reset the HU? Some do have a reset configuration by holding a certain sequence of bottons while powering on or off. Could also try removing power. Does sound the the tuner is gone.
Previous Owner of 00 SVT Contour #1077/2150
95 Contour SE '01 3L
Posts: 1,451 |
There's a small reset button that can be pushed in with a pen, pin, etc. I'm not sure if it's the tuner because AM works fine. When the FM is on there's absolutely no sound, not even static when you turn the volume way up. Really strange
Dtec Heatshield
Optimized TB
Posts: 1,605 |
Sounds like the antenna might be unplugged...
#3162 of 6535
98 SVT Silver frost
Viper Responder 791 w/ 2way remote start
Let the modding begin!
Posts: 1,451 |
Originally posted by Quick_SVT: Sounds like the antenna might be unplugged...
I thought about that but wouldn't you still hear static when turning the volume up really high?
Dtec Heatshield
Optimized TB
Posts: 124 |
not necessarily. if the antenna plug doesn't have enough of a boost to get any signal it is quite possible you won't get static either. it's happened before when I unplugged my antenna
98-98.5 Silver Contour SVT
short shifter
Panasonic HU
2 12" MTX 8000's
MA Audio mono block amp
homemade box
Posts: 24 |
AM is more dependent on antenna then FM. It sounds as if the FM is toast. Sorry
96 GL
HU:Alpine
Mids:Infinity 6x8
Subs:2 Soundstream Exact 12",Vented Tuned to 30hz
Amps:Hifonics z440, Brutus BX1605D
98.5 SVT #5035 of 6535
HU:Eclipse CD5484
Mids:eD 6500
Subs:pair of eD 13Ov.2
Amps:eD Nine.1, Nine.4
Posts: 3,076 |
what kind of car is it? some vehicles like when put together in sections alreay have the antena wires in the sections and are then connected. Some of these connections get corroded and loose connection.
2000 SVT Black/Tan #1633/2150 (a few mods)
Alpine: CDA-9835, MRV-F540, MRD-M550
PG: TANTRUM-X 6.5 COMP all around.
Some people wear Superman pajamas. Superman wears Chuck Norris pajamas.
CEL currently: Off
