#1327579 07/06/05 04:18 AM
Shtoms Offline OP
What do you use to clean the IAC and the throttle body, what should I buy from the parts store to clean it. Thanks!
#1327580 07/06/05 04:45 AM
i used mineral spirits(parts cleaner solution). but simple green or carb cleaner should work. just make sure to blow it out and don't let it soak too long because if i can remember right, there's rubber in there.
export the imports
#1327581 07/06/05 12:39 PM
Shtoms Offline OP
So just spray or pour it in let it soak for a couple minutes and blow out using a can of air? How about the throttle body, how do you actualy clean it, using a rag, etc? Thx again
#1327582 07/07/05 03:25 AM
yup, although i have never seen a can of air ...and the tb, well just spray carb cleaner in there. the yellowish color is normal .
export the imports
#1327583 07/07/05 03:38 AM
Carb cleaner-any crap will do. I got some cheapo stuff for $1.99 at Murray's.
-IAC-since the carb cleaner is in an aerosol can, just spray in one of the two holes and let it soak for a couple minutes then dump it out. It'll evaporate really quick.
-TB: I used carb cleaner and an old tooth brush and just scrubbed the deposits and cleaned with a napkin.
99 Black Contour SE Sport
