#1327113 07/06/05 01:02 AM
TAVS Offline OP
Hey -
I'm trying to figure out if my engine has a overhead cam or not. How can I figure this out? I have a 1995 Contour SE.
Thanks
#1327114 07/06/05 01:06 AM
yes, its a dual overhead cam.
probably even has "24V DOHC" badge on the each front fender.
#1327115 07/06/05 01:06 AM
The duratec v6 is DOHC (that's: Dual OverHead Cam)
#1327116 07/06/05 02:04 AM
not only are they overhead, they are dual and they are hollow
#1327117 07/06/05 02:42 AM
The Zetec 4 cylinder engine is also a dual overhead cam, so all Contours are DOHC.
#1327118 07/06/05 06:21 AM
H
H
Not only is it an overhead cam but it also retains the coveted title of "quad-cam". I envy you. Well, maybe I just want your car.
It's a good thing Ford didn't put that hideous Split-Port I4 in the Contour/Mystique. The Focus still got stiffed into production with that POS.
#1327119 07/06/05 01:46 PM
TAVS Offline OP
You can have it. I think it has a cracked cylinder block and my friend was telling me if it wasn't overhead cam, I could probably fix it myself but being it is hallow dual overhead, I think the car may be headed to the junkyard. I'm quoted $1000 + block from any garage. I'm bummed.
#1327120 07/06/05 01:58 PM
Get a 3.0L block and make it worth it.
-Philip Maynard '95 Contour [71 STS | Track Whore] '97 Miata [71 ES | Boulevard Pimp] 2006 autocross results
#1327121 07/07/05 02:41 AM
F
F
If it's a Duratec V6 it might be worth fixing it if you like the car, and it's not beat up otherwise. Or someone might want to buy it as a project. Like here: vehicles wanted
http://www.contour.org/classifieds/classifieds.php?t=2&c=2 Which would be better than junking it. What happened to the engine? Did it overheat?
