#1326833 07/05/05 08:43 PM
Okay, so it probably wasn't warped. I've had the typical problems of vibration and shimmying when I put my foot on the brake. On one occasion I had the rotors turned, and that solved the problem for a while. On another occasion I bought new rotors, and that solved the problem for a while. On both occasions, the vibration would return after a few thousand miles.
Based on the distinct possibility that the rotors weren't warped, but were only bedded improperly, yesterday I ran the car to 60 mph, and came to an abrupt stop (well, almost stopped). Then I quickly accelerated to 60, and stood on the brakes again. I did this 6-8 times, until I could smell the brakes. My idea was that I needed to re-bed the brake pads. It seemed to work. Right now, when I step on the brakes, it is as smooth as it was when I had new rotors.
Now if it will only last.
#1326834 07/05/05 09:04 PM
Usually when a rotor is warped it will keep warping, even if you turn them as the metal morphology in the rotor is already headed into that "direction".
#1326835 07/05/05 09:22 PM
My guess is you had pad residue and/or other build-up on the rotors that wasn't even. You just smoked it all off.
-Philip Maynard '95 Contour [71 STS | Track Whore] '97 Miata [71 ES | Boulevard Pimp] 2006 autocross results
#1326836 07/05/05 10:54 PM
CEG road warrior
CEG road warrior
Buy a new one...they are cheap enough.
#1326837 07/05/05 11:37 PM
yeah if you buy the cheap rotors ... personally I am not cheaping out on the brakes on my car as well as the tires
#1326838 07/06/05 03:53 AM
Scuff the pads with some 80 grit in a figure 8 pattern.
Sand the rotor surface with some 120 grit. Using a DA will help but hand sanding will work.
Re bed the pads in a sane manner.
Less Bling, more Zing Todd/TCE www.tceperformanceproducts.com
#1326839 07/06/05 10:38 PM
CEG road warrior
CEG road warrior
How so? My cheap rotors (the last set I had) lasted over a year and were not warped. Stopped pretty good at high speeds.
My supposed BAD cross-drilled Powerstop rotors lasted me over 2.5 years and were STILL not warped even with my crazy driving. A lot of high speed stopping and city stop and go driving.
#1326840 07/07/05 06:11 PM
V
V
And make sure all the lugs are torqued equally.
E0 #36 '95 Ranger '82 Honda CX500
Moderated by  Andy W._dup1
