when i step on breaks, only spoiler light comes on and not others. bulbs are ok because turn signal works on both sides. checked fuse, its ok also. Any ideas?
Well if the turn signal works (the bulbs actually light) then the brighter filaments are fine, if the spoiler lamp lights then the switch on the pedal would be fine....maybe try checking the fuses again? Pull them ALL out and look at them in light?
Don't know where to go after that, that's odd....maybe more experienced people will chime in...
1998 Mystique LS:
-2.5 Duratec ATX
-Vibrant White
=Pics==Info=
I don't know what fuses they all use....doesn't matter...Ford wires stuff oddly sometimes...like I said i would just pull all of those interior fuses and see if any are burned out....won't take that long.
You said the turn signal lights up earlier....so when you turn the turn signal on, do the rear bulbs actually blink brighter (I'm talking about the side ones)?
1998 Mystique LS:
-2.5 Duratec ATX
-Vibrant White
=Pics==Info=
ya, they blink as always.
and also, i noticed at the same as this has happened, cruise control also doesn't work....:(((((((((((
so go 2 problems, lights and cruise control
car has electrical problems, the last thing that happened was rain. it was raining for a while, but car did not stall or anything. after rain i was driving for about 40km acting weird: rpms would just up and down and no power. i had problem before with water and was stalling when got wet, but it was right away, not 40km after. any clues? maybe some stuff was shorted out. i am going to scan with computer.
Have you pulled out the bulbs and looked at them? There are two filaments. Check to see if they are both good, if you haven't already. Also FYI it's spelled brake lights.
