Well, it has been awhile since I last posted and spent a few hours trying to replace the pass. side lower control arm. I got the old one out no problem. I noticed when the ball joint was separated, the strut assembly moved out a bit. It seems the half shaft moved out of its pocket. Is that possible? How do I get that back in place? I can't tell if it was dislocated from the inner boot or outer. Do I have to remove the boots? Any help would be great. I spent all day yesterday farting around with a simple swap. (I seem to forget simple swaps are different when I have a socket in MY hand)
