How to change bank 1 HEGO sensor. Extended version:
1. disconnect spark plug wires from the coil pack. if your spark plugs are not original, it may be a good idea to mark which wire goes where
2. disconenct wiring to the coil pack and unscrew four bolts holding the coil pack in place. remove the coil pack
3. locate the HEGO sensor and put O2 w/ a 2" wobble joint and another extension on. if you plan on doing it w/o disconnecting the battery, be warned that mega fuse is located right where your hands will spend most of the time.
4. loosen HEGO sensor and remove it. if it does not budge... apply more force.
5. discover that the HEGO sensor thread got stripped possibly leaving chunks of the thread inside. curse... borrow freinds car and drive to Autozone. They sell spark plug thread chacers and repair kits. a chacer is just a bolt w/ three cut-outs like a tap. the repair kit includes actual tap and several inserts. Oh, be warned that the sales associates at autozone have no idea, so you have to find these by yourself. They sure as hell don't know that HEGO sensor thread matches spark plug thread, so don't bother asking about HEGO sensors.
6. get a chacer and go home full of hope
7. after an hour of trying, discover that due to clearance issues there is no way at all to re-thread the manifold in place. curse more...
8. count the things that might strip when you are dropping the manifold: two nuts and two studs integrated w/ a flange pressing y-pipe to the front manifold; two nuts pressing the y-pipe to the rear manifold (studs are screwed into the flange on the manifold); two nuts and expensive screws between y-pipe and the main cat (because even though you read DemonSVT's warning not to touch those when you install headers you want to optimize the y-pipe); gasket between the cat and cat-back
9.take an old HEGO sensor and wedge it in place of the stripped one. you are done till next weekend.
10. discover that car w/ exhaust leak is not really driveable (duh)
11. Monday moring call Bill and order manifold gasket, studs and nuts, also order all nuts around y-pipe, but not bolts/studs, hoping you will be ok.
12. reserve a rental for the next weekend because your wife and daughter have very important things that have to be done.
13. Friday night get a notification from DHL about the parts being shipped now (curse big time)
14. use rental to go to Chris and pick up most of the parts you need
15. come home and discover the package from Bill delivered (this is important, we will see why later)
16. start disassembling things. snap expensive bolts (what was I thinking, of course they had to snap), snap oneof the studs on the rear manifold curse excessively and with feeling... if you have a 20" extention, one wobble and deep 13mm socket, you can reach every stud from between the body and subframe (you have to find a good angle, but it works and you don't really need gear wrenches which you just got from Sears). there is no need to move the alternator out of the way. drive to autozone (you still have a rental) to get a wrench for the EGR pipe. you will save yourself a lot of effort if you know the size of the wrench you need (you can cheat: I know it's 1 1/16"). if you are not sure what size you need, don't take 1" and come back for bigger ones, get several wrenches in one go and return them later. they are around $18 each, but they will take them back w/o a fuss.
17. re-thread the manifold. use a lot of WD-40 to cact all the shavings in the chacer. you are done till next weekend
18. call Bill monday morning and present him w/ the butcher's bill
19. don't worry about the package from Bill because you know he ships on Friday overnight
20. discover that the package did not come
21. try to screw out the studs from the manifold... curse... curse more...
22. it's 90 degrees outside so take the manifold and walk around town to find any mechanic that may be willing to help you
23. come back home, cut off the studs and start drilling them out
24. discover that grade 8 studs are tough on drills
25. drill out the studs completely.
26. screw 6 studs in, put the gasket on and try to put the manifold on... alternator is in the way now. screw out all but the leftmost studs and put the gasket and the manifold on. now screw in the studs again. put the nuts on and tighten them from center out in a zig-zag pattern. you are done for the weekend
27. call Bill Monday to find out what happened w/ the package and re-order everything again. email and call Bill Tuesday to see why didn't the package go out Monday. repeat the same procedure on Wednesday.
28. take out remains of the y-pipe-to-cat bolts. use heat and BFH. use drill to take out whatever's left.
29. put everything together.
30. discover that nuts you got from Bill for manifold studs are not the ones you need -- use old nuts.
31. fire the car up. you are done
32. try to remember that if you leave your family w/o a car for an extended period of time, advertizing of $199 a month lease on a Mazda 6 really gets to you and your wife.
I hope you had a laugh. I certainly did not. I almost got a heat stroke when I was trying to get some local mechanic to drill out the bolts for me... last time I replaced HEGO sensors on my '96 it was so uneventful it was boring.
hehe./
is this a how-to, or a how-to-not, or??
Want me to sticky this?? LOL
Sorry to hear about your LENGTHY misfortune. Ask me about my fuel ralk quick connectors and the associated fuel lines that you CANNOT replace in pieces. (must be done from front to tank ) and about how long the car was undriveable for!!)
I truly empathize with you.
congrats on getting 'er going, again/.
ray
That was disturbing to read.
But at least it's over, eh?
1998 Mystique LS: -2.5 Duratec ATX -Vibrant White -------------------- =Pics= =Info=
W
W
wow. I hate days like that. I haven't had many lately but when I was young and playing with cars I had many!
H
H
Wow. My weekend changing a sensor was mundane and boring compared to yours. I feel very fortunate now.
I changed my TPS, cleaned the MAF, put on two speedbleeders (what do you mean tehy don't come in pairs?), flushed the brakes, changed the oil and rotated the tires - all before noon on Saturday. Well, if it makes you feel any better it took two weeks for me to change my LCAs:
1. Order LCAs from 96BlackSE
2. Order Bolts from Bill
3. Jack up the car, take off the wheels
4. Start loosening the subframe-to-LCA bolts.
5. Get sick of that, attack the ball-joint pinch bolt.
6. Snap the hex socket
7. Get a new hex socket and a torx socket
8. Strip the Torx end.
9. Strip the hex end. not easy with a 6-point socket.
10. Attack with the grinder
11. Cut off the nut
12. No dice
13. Torch it
14. No dice - but I burned a hole in the CV boot
15. Break off the head because the hole looks threaded
16. Drill it out
17. Whoops - not with HSS
18. Whoops - not with Titanium Oxide
19. Ah- Cobalt!
20. Whoops - the knuckle is much softer than the bolt. It's very hard to keep the bit centered.
21. Not enough clearance. Cut out the LCA with the grinder
22. Not enough clearnace: cut off the ball-joint with the grinder
24. Post online - Ray says it's not threaded
25. Try pass. side: it comes right out. Ray was right.
26. 5 lb hammer and socket extension get it out.
27. Back to the LCA bolts
28. Pop them up against the tranny
29. Jack the transaxle up to get some clearance
30. Start cutting with the grinder - very tough to fit in under there!
31. Get paranoid- check the bolts Bill sent - yep, some are the wrong ones.
32. Cut the bolts off anyway.
33. get the LCA out
34. Wedge the new one back it
35. Won't go: the CV joint is stuck out
36. Try harder. Try all night. Go to bed.
37. Next day: try again and get it
38. Bolt it all up with new hardware from NAPA
39. Whoops - not enough tranny clearance. Cut the bolts short.
40. not enough thread to cut them that short. Make spacers out of 1/4" flat stock.
41. Bolt it up again.
42. Onto the passenger's side.
43. All goes well. WTF. Only 2 hours over there.
44. Test drive!
45. Oh crap, the CV boot. Grease is every where.
46. Get a new CV boot: I order the easy-fit split kind. It'll be in wednesday.
47. Wednesday: whoops, not in. Tomorrow.
48. Thursday: whoops, not it.
49. Friday: Ah, here it is! Whoops, it's a real boot. Oh well, I was hearing bad things about the split boots.
50. I take the axle off HOW???? I think not.
51. Ah-ha! Moment of genius: Pull apart the inner CV boot.
52. Stumped by very stiff snap ring
53. Chop up some needlenose pliers to get it.
54. Wrestle the tripod off
55. get the snap ring off, and pull off inner boot
56. hack off the cut boot
57. slide on the new outer boot
58. slide on old inner boot
59. Crap, how do I get on this ring?
60. wrestle on the rings/tripod
61. Can't get these metal bands to work. Zip-tie the boots on.
62. Go to an autocross and see an Formula SAE car with zip ties on the tripod housings - yes!
63. Find a snap ring on the garage floor
64. take the whole thing apart again. Nothing is missing. This time I bought snap-ring pliers and a CV boot clamp plier. So much easier!
65. Finally rest in peace!
66. get camber kit - realize I need to take apart the suspension again - Oh, no...
To be continued
-Philip Maynard '95 Contour [71 STS | Track Whore] '97 Miata [71 ES | Boulevard Pimp] 2006 autocross results
you forgot to mention that someone besides Bill -- ahem -- sent you a wrong bolt .
Ah yes, let me see what happened: Bill sent you the wrong bolt (or did he?) so you sent it to me. I'm still confused about that one. If Bill AND you were wrong, then I would have gotten the right bolt. However, I got the wrong bolt, so I assumed you were wrong. But then, you did the install and knew what you needed, and said Bill sent the wrong one. But Bill sent me the wrong bolt too, so you couldn't have been wrong, because if Bill sent you the wrong bolt and you needed the one I didn't need, then it would be the right bolt. But it wasn't, so maybe Bill sent you the right bolt. But if you knew what bolt you needed, then you knew it wasn't right, and wouldn't have sent it to me... OUCH! Nevermind, it happened how it happened!
