ok, without going into too much specifics, the simple fact is, that if you have to ask the question that way, means you should do some research on general engine stuff.
Not trying to be a jerk, but if you go to the library, or a good bookstore, get a book on general automotive engine stuff, and learn as much as you can about how an engine works, and what increasing compression ratio actually does, and what other things need to be done to accomodate an increase in compression.
