O
O
I had a bad noise coming from the front end, so I checked the bearings and the pass side was defenetly bad. I finally got the knuckle off (after struggling with the bottom ball joint). After I got everything out of the way, the inner CV boot is also leaking grease, so I wanted to pull the CV and replace it. Right now I can't get the CV shaft to slide out of the trans (carrier bearing extension). I can't see how I can get a pickle fork in there from underneath, and can't pull it straight out. Any tips?
Plain-jane 3.0L supercharged E0 FOR SALE OR TRADE FOR STOCK SVT PLUS CASH WTB- 36# return injectors
Learned patience the hard way
I always take a long flat punch and use it with a hammer to tap on the inner CV housing to separate the shaft from the center section and carrier bearing. I think it requires you drop the y-pipe to really get good access, but other than that it's easy.
Rick
Owner of 00 #1611 Silver (Totalled) 98.5 T-Red SVT #6180 Buckshot77@msn.com Misc 3L parts for sale
O
O
Rick
thats what i thought
My best friend... Slide hammer w/ CV attachment. About $70. Slide it up between the shaft and tranny. Slide the handle up and give her a couple good yanks.
E
E
I usually just use a fat chisel and wedge it in between the shaft and trans housing. Give her a few taps to pop the shaft out. Works great for me. Just be careful not to nick the shaft seals. If they look crusty at all, it would be a great time to change them.
95 Contour, Custom EVO bodykit, 2.0l, PNP Focus head, Stage 2 cams, Je pistons, Eagle rods, 4in1header, 2.5" header back exhaust(complete stainless), D P nitrous, ram air intake, 10mm wires, flamethrower.
Nice ! I will have to get one for sure .
Check me out for awsome powder coating deals www.powdercoatingworld.com People shouldn't slam each other when posting, If you cant say something good to say then just hit the back arrow.
I got mine with a pick a fork! Maybe have to take the y pipe off. Is it THAT hard...saves time in the end.
