Posts: 2,708 |
The S-AFC is designed for Cars using a "Speed Density" calibration system which doesn't use a MAF. (typical Honda, Nissan, Toyota, etc...) From what I have gathered from various tuners using this on a MAF equipped car like a DSM turbo, the S-AFC doesn't read the MAF signal correctly at idle causing a rough idle. Stazi (being a former DSM owner) can probably elaborate a little better then me.
-Mark
You can do something for Love... You can do something for Money... But there is nothing quite so satisfying as doing something out of Spite. GTExtreme1@aol.com
Posts: 3,562 |
In the set up, you get to choose from a pressure system (MAP) or a hot wire set up (MAF). Once this is chosen, I don't see how it could mess it up. There are some DSM web pages on how to get a basic set up using this piece as well, I forgot to bookmark that page... guess some more searching is in order again... now what did I search for last time... hummmmmmmm...
Brad Noon '99 SE MTX 3 point oh my God H.O. 179HP/178TQ BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!bnmotorsports@msn.com
Posts: 1,003 |
All the big DSM tuners (Road/Race Engineering etc..) think that the S-AFC is pretty swell, according to their website. They even provide starting tuning points for DSM cars w/different mods...
The S-AFC technical documents are on APEXi's web site, including wiring diagrams, and all the technical info one might need in order to hook it up, yo. Try the link at the top of the post for more info.
And yes, one has been hooked up and works very well on a local Mustang here in Denver! This should work for Contours...
Alex in Boulder, CO
Posts: 443 |
The DSM guy's that had trouble with the idle are trying to use blow off valves that dump into the atmosphere. DSM's ARE MAF controled,with a MAF system the blow off valve MUST dump back into the system after the MAF. With a Speed Density system you can blow off into the atmosphere.
Posts: 2,708 |
That might be what I am thinking of.
It looks like I might be looking into getting one sooner then I had hoped.. I changed my plugs lastnight and the white/tan carbon on the electrodes is proof enough that I am not getting enough fuel. Time for bigger injectors & the S-AFC... maybe some other goodies along the way. -Mark
Posts: 98 |
I am pretty sure my cougar is running rich, ever since I gutted the precats my car has more soot coming out and smells really bad at wide open throttle. I have been looking around but none of the magazine adds really specify if the AFC is universal or not. Will I need to use a dyno to adjust my AF controller then? Can't I just do it my self.
Thanks, Chris
1999 V6 MTX Black Cougar
Jacobs ignition system, Borla dual exhaust, Sho shop y pipe and hi flow cat, gutted precats with MIL eliminators, IAT rewire, vitek ignition wires, SCA CAI with monster flow filter, Unorthodox racing pulley, BAT rear strut brace, Battery relocation to trunk, eibachs, KVR crossdrilled/slotted rotors, freedom design strut brace and Tuned S-AFC
Waiting to be installed: svt engine with 11k miles on it/ fidanza flywheel/Quaife/energy suspension engine mount inserts.
Posts: 3,562 |
Originally posted by Blackcoog: Can't I just go to a dyno shop and have them do it for me?
Thanks, Chris Yes, go to a shop that has experience with the S-AFC and it'll be fine. The other part of the discussion would be for the majority of the do it yourselfers out there in CEG land.
Posts: 3,237 |
Originally posted by RedSVT: The DSM guy's that had trouble with the idle are trying to use blow off valves that dump into the atmosphere. DSM's ARE MAF controled,with a MAF system the blow off valve MUST dump back into the system after the MAF. With a Speed Density system you can blow off into the atmosphere.  He is right there. The DSM ECU cannot hanlde atmosphere dumps as it has already ":counted" the air coming in and on shifts the dumped air dramatically decreases the A/F ratio (richer) and causes the engine to stumble. The DSM's use a Karman Vortex type of MAF. It counts eddies in the airflow to calculate the mass of air entering the engine. The Apex S-AFC is compatible with different types of Air Flow meters, I just hope that the Ford style is one of them. I am thinking it should work. Give it a try Mark. I wish I still had mine! :rolleyes:
Posts: 2,708 |
I think there is something that I need to fix before I go spending money on this... -Mark
Posts: 154 |
Hey fellas. it will work fine on maf. I meet a guy with one on his focus. it idled fine and he said that it helped alot down low on his car and it had not been dyno tuned yet. he suggested that i get one for the tour. I will let ya'll know cost on one so you can see how nuch these guys are making off of us. i plan one geting one soon. furniture and rent come first though. as you know i just moved to cali to work for a major performance company. alot of cool stuff iam doing research on to see if it will work for our cars. coming up with good stuff but will post more when i have complete information about products.
later
eric
Eric 99 SE MTX Flowmaster muffler, no Res, Weapon r filter, 80mm mustang mas, Air/fuel guage, oil pressure guage 2 pod guage pod, B&M shifter, Hyper white bulbs, white front corner lights, Mobil 5w-30 syn, K&N oil filter, Air/Fuel optimizer SVT throttle body real soon! 14.7 @ 92 Best time 15.2 @ 93 Best MPH
