Posts: 1,603 |
Originally posted by jd28: It's best to have the flush done which requires equipment (you have to go to a shop that does it). Back flushing the ATX fluid under pressure to get the stuff off the filter screen. Other methods will not remove as much.
JD
Flushing a tranny doesn't do a BACK FLUSH. Where did you get this info from?
The equipment used for a flush connects to the cooling lines and pumps into the transmission the same amount of oil the transmission pumps out into the machine. There is nothing special about this machine. It just replaces the old oil with new oil.
What it is very good at is removing suspended particles from the transmission by capturing them within the old oil it is removing.
Pete...
2004 Mercury Marauder 300A
Black Clearcoat/Dark Charcoal LEATHER
DOB 10/31/2003
DOP 1/2/2004
www.mercurymarauder.net
Posts: 1,603 |
Originally posted by ALIAS Jerk: trannie taking a dive then? Last I knew you didnt know if it was dying or not... We were having that problem with her mom's taurus on the way up north to our camping trip (crappy trip). RIGHT out of midland the Overdrive light started flashing on that hot a humid day, Strange thing was... The overdrive would only freak out when you used the cruise control.
Cruise control relies very heavily on the Torque Converter Clutch. If it is not working properly, you will get the blinking OD OFF light very quickly when using your cruise control.
Pete...
DOB 10/31/2003
DOP 1/2/2004
Posts: 508 |
It replaces fluid with new fluid in reverse to get the junk off the screen. If it flows the same direction as it would when the atx is running, whats the point in even doing it? You would have clean fluid and a clogged screen. It also helps make sure the TC is flushed out.
JD
JD a.k.a Fingers
"Don't Panic"
'98 Contour GL 2.0L VCT ATX 88k
'98 Contour LX 2.5L MTX 120k
Street racing can kill
just less of a chance with a 2.0
Posts: 1,603 |
Originally posted by jd28: It replaces fluid with new fluid in reverse to get the junk off the screen. If it flows the same direction as it would when the atx is running, whats the point in even doing it? You would have clean fluid and a clogged screen. It also helps make sure the TC is flushed out.
JD
Explain to me how you pump oil back through the transmission oil pump BACKWARDS ????
Or did you think it was as easy as it sounds ???
Flush does exactly what it is meant to do. Flush out the old oil and replace it with fresh oil. It does NOTHING else. It also only works with the engine running.
Pete...
DOB 10/31/2003
DOP 1/2/2004
Posts: 508 |
I don't know why I was thinking that. I must of though something stupid like that to justify spending 160 on my last flush.  I did some reading and you are correct (should of did that before I tried to sound like I used one before) I was thinking it was done with the car off.  JD
JD a.k.a Fingers
"Don't Panic"
