As easy as they are to remove on some cars (Taurus, for example), I thought it might be worth swapping in a junkyard-pulled VR rather than the whole alternator. Two questions...
1) Are all the Ford VR's that physically look the same as the one on the Contour, actually the same part? For reference, here's the p/n directly off a VR that I removed from a '95 Taurus: F4ZU-10316-AC Does anyone have the p/n off the VR used on the Contour?
2) If I only want to swap the VR, does that make for an easier job on the Contour? Even if the VR can't be removed with the alternator in place, maybe I can just loosen the alternator and move it enough to provide clearance?
Any and all feedback appreciated.
Brad
