How often does it need oil? (how many miles before you need to add more) Does it smoke right from the time you start it or does it go away after a bit? You might have some spent rings or possibly some bad valve stem seals. Also, when is the last time you changed/cleaned your PCV valve? If it isn't relieving the case pressure being built up, it will make the oil push into places it doesn't nee to be and will cause it to burn your oil and smoke alot.
95 Contour, Custom EVO bodykit, 2.0l, PNP Focus head, Stage 2 cams, Je pistons, Eagle rods, 4in1header, 2.5" header back exhaust(complete stainless), D P nitrous, ram air intake, 10mm wires, flamethrower.
