ok, i never liked my 5 speed on my cougar, though this is the car a learned stick on and have gotten quite acquainted with it i never like the slowness in shifting and smoothness problem with my tranny, i order the redline mtl and put it in last friday, my trans now when i put it into gear shifts quick, firm, and smooth, i love it! DO THIS TO YOUR STICK NOW! unless u have synchro problems already u will love this stuff.
-Steve-
2002 Cougar 2.5 duratec/ mtx-75 85,0000 Mondeo ST-200 wheels/BFG KDW NT black/black Spec Stage 1 Torsen T-2 Trubendz 2.5 flowmaster dual exaust apexi s-afc II K&N FIPK
I have it and I added some as well , although I didnt fully drain all the fluid out ...Is there some sort of a drain plug ? on the MTX ?
Check me out for awsome powder coating deals www.powdercoatingworld.com People shouldn't slam each other when posting, If you cant say something good to say then just hit the back arrow.
It's amazing what you can find here if you look around.
http://www.contour.org/mods/mods.php?s=howto&displayid=38
its the bolt towards the bottom of the tranny.
I like my Redline.
9
I think I'm gonna do it soon. I have trouble invisioning a smoother shifter though, mine is pretty smooth already.
You only fill it to the bottom of the threads correct ?
fill till it starts to come out of the fill hole, just like a transfer case or a differential.
Thanks will do .
If you don't know where the drain plug is, how did you let any fluid out, period?
So your basically saying you just added fluid on top of what you already had?
