it is not bad at all if you have the proper tools and knowhow
with that being said I post instructions for the pre 98 and another member posted instructions for post 98 cars
make sure you change all the pullies when you change the belt and you might concider the water pump also as you need to remove the timing belt to replace it
otherwise take your time and make sure you do everything right
