Usually any time spent in the read zone will cause the head gasket to go and possibly the head to warp. If the fan was not turning on then the damage could have already been done. I would check for a blown head gasket. Check the exhaust to see if there is any smoke coming out of it. Pull the dipstick and see if it has just straight oil in it. Look in the coolant bottle and see if there is any oil mixed with the antifreeze. Have a compression check done on the cylinders. I would also have a system pressure test done - this will let you know if there is a leak in the system. A faulty water pump would leak or grind. Have you done anything with the thermostat?
95 Contour, Custom EVO bodykit, 2.0l, PNP Focus head, Stage 2 cams, Je pistons, Eagle rods, 4in1header, 2.5" header back exhaust(complete stainless), D P nitrous, ram air intake, 10mm wires, flamethrower.
