BOO switch (Brake On/Off) located on the brake pedal stalk, behind the metal bar that moves when you press the brake pedal.
it is a normally closed switch that is released when you press the pedal.. it likely popped off the mount that holds it right behind the pedal and is now "always" released.
Ray
