#99598 06/27/01 11:58 AM
N
NickP Offline OP
N
Has anyone installed a multi spark ignition box on a V6 tour? If so, what was the result?
#99599 06/28/01 12:26 AM
Without considerable modifications, this is just SNAKE OIL! Even with considerable modifications that still might be SNAKE OIL. Don't waste your money.
Jim Johnson
98 SVT
#99600 06/28/01 12:35 AM
Don't get one for the v6. I tried the Jacobs and it did *squat*. Someone else actually dyno tested theirs and it lost hp.
However, the zetec's seem to like them.
dan
#99601 06/28/01 02:50 AM
your stock ignition is more advanced I toyed with the idea of getting one with timing control but decided against it.
98 silver frost SVT
custom built intake, offroad y-pipe,mystery mod,remote optimizer,short shifter,zex nitrous, lots of stereo, 17 konigs
with paradas.(bent) TOTALED do to freak electrical fire?(that started at a wireing harness ford neglected to tell me should have been recalled as they did with the 95se) I miss this car.
NEW PROFFESSION AS A TROLL.
new car. 2000 dodge dakota 4.7l v8. custombuilt intake, custom exhaust, kennebell pcm, and electric fan conversion, 180 stat, 3.55 pegleg, my old stereo system, 17x7 billets and 255-50 nitto 450 tires. next drop and traction adders. g-tech 14.5
in search of 95 se fivespeed to hang contourparts on.
#99602 06/28/01 03:46 AM
Snake Oil Big time...
Jacobs, Nology, etc All proven to have no performance gain or actually hurt performance.
The DIS system on most OBD-II cars is far superior to anything you could get in the aftermarket without laying down some serious cash (I.E a custom PCM setup = $2k+)
2000 SVT #674 - Check it out!
#99603 06/28/01 03:48 AM
Like any snake oil product, it does the job it was designed to do very well. Unfortunately it was not designed to improve engine performance. It was designed to transfer money from your pocket to theirs.
Jim Johnson
98 SVT
