Salvin Offline OP
Ok been out in the garage for 2 hours now and that %�¤#%#%�¤%& plastic cover on the A pillar wont come off, i'm pretty sure it's real easy if u know how to do it. I need to take it off so I can put a gaugemount on it , but i'm close to giving up right now
the car is a 2000 svt contour
Any help would be much appriciated.
Yank that biotch off. I broke the tabs that old it on and said screw it, i have to drill holes to hold the new one on anyway.
Actually I think it releases in an up and down motion
www.ChicagoCEG.com 2006 White Grand Prix
9
push in on it then pull up on it..very simple...
remove the door weather strip. (top part)
press the pillar inwards towards the a pillar frame (like compressing a spring)
slide upwards, towards the roof line, to slide the pins out of the slot they are held in.
the entire piece should fall away after it moves upwards about 1/2 inch or so.
Ray
You guys are such sissys!!!! BREAK IT OFF LIKE A MAN!!!!!!
When I installed the gauge pod on my old blue Zetec it broke off on me. The duratecs ine though, but I couldnt tell you how I ot the pillar off without breaking the tabs.
Salvin Offline OP
Tried the compressing and pushing but it only moved 0.5 centimeters
maybe breaking it off and buy a new one will be the the easy way to do it , the only thing that has come off now if one nail and skin.
Did you get the gauge pod from Lotek with the three holes or is it a different one?
Salvin Offline OP
I wish!
couldnt find anything that was fitted for the model in Europe so I bought a universal tripple crap holder that took 3 hours to modify so it would fit on the factory A rod.
All thought I did get 3 Ultra-light gauges for it so any bad fitting will be balanced by the bling of the Autometers
