Aluminum HiFlow Y-Pipe from Sho Shop:
Free Flow catalytic convertor:
I was told the cat is removable. What exactly does this mean. At will i can take it out, for say going to the track? Is it that easy? Can someone shed a little light on this? Thanks
Silver 98 SVT Contour E0
#4124 (Currently on Life Support)
Built 11/97 Bought 1/98
Eibach Pro Kit \ Koni \ Niche Pultec 17"x7.5 \ Yokohama Parada 215/17/40 \ Shaved Wheel wells / Brembo-KVR Cross Drilled Rotors / KVR Carbon Fibre Brake Pads / Aeroquip SS Brake Lines \ 21mm Rear Progress Tech. (Powder Coated Black) \ Superchips Auto Meter Pro Shift Light \ Extrude Honed \ Stripped Resonater Street Scene Free Flow Exhaust \ Injen Technology Prototype CAI \ Weapon R filter \ Hose Techniques Red Kit \ Folia Tec Red Caliper Paint \ MOMO (shift knob, pedals, seat belt pads) \ Clarion, Sounstream, Kicker \ Optima Red Top Battery \ SVT Emblem Mods
Jet Hot Coatings (25-30% Cooler) on Upper Intake Manifold, Sho Shop Y-Pipe, Cat, and CAI
"Come Out...Come Out Where Ever You Are"
http://www.geocities.com/speeddemons19
Im not posotive but I know the Cat comes off for "track use"...most likely it is just bolted up and all you do is unbolt it..should be to difficult or tiem consuming...but someone correct me if im wrong.
2
2
When I got my Y-pipe, it was in 4 pieces. The 2 downpipes, the cat, and a flex pipe to connect to the rest of the exhaust. It all goes together with clamps. I had mine welded because the clamps were leaking.
I guess you can unclamp the cat and have dual open exhaust.
Hope this helps! cool
"Talking is masturbation without the mess"...Our Lady Peace..
This is my car....
Well, just like the bolts that don't come with the kit frown , you can also buy a pipe cut the same size and just replace the one currently bolted in there so it is off road.
Merlin
281hp 324tq
Timing 14' FP 36,24lbs,190lph,75Maf,65tb,cobra upper&lower,B303, GT-40 Crate with X al heads, Mac shorties, Off Road H,2chamber Flow's dumped, Tokico 5wys, Hotichkis Ctrl Arms, Alum Drive shaft, 3.73, Sub Frame,Steeda Tri-Ax, 94 Seats Drivers side powered.
N
N
You can unclamp the cat and slide it out without disassembling the exhaust system. At the track, you could slide in a y-pipe and race with very little time and effort.
98 Black E0 #946 of 6535
Koni struts & Eibach springs
24mm Aussiebar
Pro Flow 75mm MAFS calibrated to KKM filter
Wilwood Brake Kit with cross-drilled rotors
Clutchmaster's Stage 1 Clutch & Fidanza Flywheel
Custom Dual Exhaust with an Xpipe
MSDS Headers
Custom Cold Air Intake with KKM filter
Dyno'd at 177 hp and 156 ft-lbs
Are we talking about a exhaust cut-out?
And does the clamps come with the y-pipe?
2
2
The Y-pipe includes the clamps for connecting the parts, just no bolts to connect the Y-pipe to the front manifold, or to the rest of your exhaust.
I've got a diagaram in case you want it, it will help!
This is my car....
my y-pipe is on the way. could you send the diagram my way?
svtstpete@hotmail.com
thanks!
- Pete - 00 SVT SF/MB - 1522/2150 - DOB 1/12/00
92% says your group-NOT HOT
85% says your either wrong or BLIND
Blackhawk Down did NOT suck
you know who you are.....
A diagram would be great. You can send it to my email.
pcjones@hotmail.com
Phillip Jones
99 SVT Silver Frost
Slightly Modded
How 'bout a diagram to Bicycle019@hotmail.com or just post it here?
Alex in Boulder, CO
