Last winter my blower switch stopped working (well, it worked occasionally), and my turn signals worked occasionally, but not often. The problem was with a fuse in the box under the dash. The same fuse (can't remember the number now) controls both functions. As it turned out, the fuse was okay, but the connection was loose. I took the fuse box apart and tightened the connection, and everything is fine now.
