Page 5 of 8 1 2 3 4 5 6 7 8
Originally posted by Aussie SVT:
3 more people and we are ready to Rock and (not) ROLL!
Bad ass quote there. That should be your "selling line". smile Also, I'm pretty sure my email server is shot, so you could private message me about my questions, if you wouldn't mind.
Thanks!
STD's are like Pokemon...
Gotta catch em' all!
Dan,
For the record, I have the SCA bar that once clunked and now does not. The difference? I replaced the polyurethane bushings with new ones and the clunk went away. For the record, I don't have the weld-on bracket fix.
-Kurt
-Kurt
"I'm a little sceptical of that internet thing. After all, what's it got besides information?"
-DB, 1/97
Dan,
The bar when installed with all the components; Prothane Polyurethane Endlink Bushings, and Prothane Polyurethane Sway bar bushings (with dacromet coated steel brackets) should eliminate any chance of clunking or creaking, as all interfaces will be supported by poly bushings instead of the junk rubber OEM bushings. The stock endlinks are retained, but the stock bushings on the endlink are replaced (see pictures). The bracket supplied is not used, the way I have the bar on the car. The stock brackets are opened slightly, with the help of a vice and pliers to accomodate the slighter chunkier sway bar bushing, BUT I will provide a template to create a weld on backing plate that can be used to increase the strength of the stock backing plates AND make use of the supplied brackets if people so desire.
I haven't had to use them (the supplied brackets), and I have not visually seen, nor heard any evidence of a problem to require to do so. But the fact that you will have brackets will allow each user to add them if a problem does arrise.
Regards,
Anastazi
Father of the Aussie Bar
anastazi.sarigiannis@aam.com
I will be sending out payment information this morning. First ten people will be able to receive early shipment.
Regards,
Anastazi
Appreciate the info Aussie, perhaps the endlink bushings are the difference. Got to think about this as I have the SCA bar.
Will you sell the endlink bushings separately?
Will your bar be avail in future is is this just a one run deal?
Munson, what new bushings did you use - did you get a redesigned peice from SCA?
Thanks.
1999 Amazon Green SVT Contour (#554/2760)
Stock SVT Duratec V6 with:
Intake- K&N filter/75mm MAF meter
Exhaust- MSDS Y-pipe/Bassani catback
Durability-Ford "dual mode" damper, Mobil 1/K&N oil filter
179.2 FWHP at 6900 RPM
I posted several days ago i would get in on this, but my name (Allyn 48) wasn't on the list.
So put me down.
E-mail lonhowell@hotmail.com
Correction: Lon Howell...I am on the list.
Didn't see the 2nd page on the thread.
Thanks.
I can sell you the endlink bushingss separate, they are $15
Also I am in negotiations with BNMotorsports and have had inklings from other vendors also, so I HOPE that this will Not be a one run deal.
Understand that vendors will have to add a markup to make it profitable for them to supply the bars in the future. It's only fair. Thus the reason why I am running a group buy now.
Buyers please note that total price with shipping is $120
Regards,
Anastazi
Did you try SPMotorsports? Seems like a nice guy there...
Actually 41xx chrome/molybdenum alloy
steel is "low alloy". You probably meant
"low carbon".
Originally posted by Munson:
It's also nice to see that the bar is 41xx steel instead of some junk low alloy bubblegum.
1996 HC mondeo LX
Radiant red
2.0L Zetec, 5sp
http://www.crosswinds.net/~mondeo/
