#1307045 06/15/05 09:36 PM
E
E
What makes the best homemade heatshield? I've heard metal one's dont work as well as other materials. I think i saw somewhere on here that a waste basket works??i dunno. i'd appreciate any ideas.
1998 E0 T-Red SVT #1223 of 1653 OLD CARS -1995 Thunderbird 4.6 V8 -1984 Porsche 944 (rustbucket)
#1307046 06/15/05 09:51 PM
I JUST finished mine, like 2 minutes ago. used a small rubbermaid trashcan. I hear a material called lexan (found at home depot) works well too.
1995 SE 2.5L V6/MTX 187k
#1307047 06/15/05 09:53 PM
E
E
How big and how did u install it
#1307048 06/15/05 10:17 PM
I can see how a rubbermade trashcan could work well. Also, metal is fine to use IF you insulate it. I fabricated mine out of sheet metal, and then padded each side of the metal with a half inch of good foam and then covered it in black vinyl, for a total of one inch thick foam. It works very well, i posted on the results several years ago, but the intake temp was at least 30 degrees F cooler than the engine bay.
The disadvantage to using metal is that it takes a good bit of fabrication work and bracket making.
I'll try to find pics, the server isn't working right now
99 T-green svt K&N & heatshield Opt. y-pipe Borla Superchip DMD Magnecore wires Metal impeller water pump BAT / Bilstein kit 21mm BAT bar w/ boxed subframe 215/45/ZR17 Toyo Proxes FZ on Rage 5.0's jimmkreider@yahoo.com
#1307049 06/15/05 10:47 PM
Here are some of the pics:
heat shield pics
#1307050 06/15/05 11:02 PM
small. there weren't a whole lotta sizes, I just went to walmart and grabbed like a 15 quart trash can. I cut away one of the sides, then trimmed it all down to fit around the filter, and the bottom of the can I fitted around the MAF as best I could. used pipe insulation (foam) around the top edges to make a "seal" when the hood closes.
I dunno, I'm not very pleased with the way it came out, it really crowds the filter, and it makes it sit really close to the hood (touches when latched). I guess it'll serve it's purpose for now, til I have time to fab up a better one.
#1307051 06/15/05 11:05 PM
Here are mine, everyone can tell me metal wont work until they are blue in the face. Ive tested for myself, and it works quite well. Fits snug enough to the hood, and the inside has a layer of alumninum tape to help insulate.
The idea was to block off *most* of the hot air, not seal the filter into a chamber.
Wonder if anyone would buy something like this. Too bad Dtec probably ruined any chance of someone selling heatsheilds.
#1307052 06/15/05 11:27 PM
U
U
cst99 is right... One made from metal takes alot of work to fab together. I was going to make a bunch of these for some people, but decided aganist it since it was so labor intensive. Here's a library, hosted thankfully by Hetfield, that contains a ton of pictures that I have taken of my heatsheild. I used aluminum and I must say that it works really well. You would think it would bake the filter, in stop and go traffic, but it really doesn't. The filter is pretty much cold, to the touch, at all times.
My opinion... For the money, you would be better off getting a GMK intake rather just a heatsheild. That is unless you are willing to build one of these. Reason is, because the labor involded in making one of these merits the price at about what a GMK intake would cost. If you are willing to do the work yourself, I feel that you would get better results from this style heatsheild... hands down.
So all in all... it's a matter of what you are willing to do yourself compared to the money you are willing to spend.
Phillip Jackson `98 Mystique LS 262K+ and counting... ATX rebuilt @ 151K "This storm has broken me, my only friend!" RIP Dime
#1307053 06/15/05 11:27 PM
I think that looks great, any chance you could post all dimensions? I have made three different HS for my SVT and one for my SE, and revise each one trying to make it better. Looks like you have developed a great part.
Mark
1999 Toreador Red SVT, DOB 4/22/99, 2005 Of 2760. "Many posted questions are answered by farm boys"
#1307054 06/15/05 11:33 PM
I might post the dimensions, Id have to go measure them tho. i still have my little cardboard mock up too, so might be easier to measure that.
Im going to look into getting the basic shape cut out in large quantities, perhaps people would be interested.
