For my MTX75 swap into a Taurus I have a set of 98 'tour cables. I have cut the obligatory hole and run them from the shifter to under the the hood. IF they fit once the driveline is in place they will be VERY tight...
The dealer shows two different part numbers before and after a mid 98 build date. Does anyone know if either of the two sets is longer or know of another car that uses the same cable ends and retainers that might be longer? I checked and the Cougar uses the same part nubmer as the 'tour as suspected.
Maybe does someone have a cable set from a 99 or newer that they could measure? My local dealers have none in stock so I couldn't even compare there.
Thanks,
Scott Krietemeyer
"Project Rowboat"
http://www.venom.org/shofiles/project_rowboat/DSCN3201.JPG
