#1305382 06/14/05 04:00 PM
Has anyone bled their clutch, manual trans 2000 SVT MTX-75? Why did you do it and what was the result?
Thanks so much :-)
#1305383 06/14/05 04:19 PM
Air in the clutch will cause the inability to release the pressure plate, even though you have your foot pressing the clutch in to the floorboard. (may cause grinding when you try to shift, etc..)
The clutch uses the same system as the brakes, and as such, you should probably bleed the brakes as well, if you have a significant amount of air (enough to be causing problems is REALLY significant).
Same as bleeding a brake system except that when you "pump" the clutch it won't ever get hard like the brakes. just keep pumping, 10-20 times, then hold (even though it is still soft) and have the other person open the valve... let air out (while you are holding, still), then tighten the valve. repeat procedure until fresh fluid flows from the valve, topping off the brake master cylinder as it gets low.
Ray
#1305384 06/14/05 08:22 PM
Wow, that's exactly what's happening. I am taking it to my regular shop tonight, not a dealer, and having them give this a try before I spend $1200+ on a new clutch, etc...
I will ask them to bleed the brakes as well. Thank you so, so much!
