Posts: 289 |
OK I finally figured out how to get the power steering thing out and took out my computer. So I started cleaning the pins when I noticed that the little sponge was completely worn, and was not doing anything anymore. But the thing is half of the pins were copper color and other half was silver. What color should they be? I called superchips and they told me it should be copper, and on the instruction sheet it says silver? Anyways for right now he's sending me some more sponges to clean the contacts. Oh by the way I did try it and the car wont start. So either wrong code or dirty contacts. Thank you
98 SE V6 ATX 15" EPIC Chrome Rims Aftermarket Foglights GTO Blackouts Alpine 7840 Pioneer 6895 In back, Pyles in front 2 MTX 6000 10" Subs MTX 220D AMP Limo Black Tinted back windows KKM SVT Exhaust SVT Grill AIM: CoOlVaD14 ------------------------- Coming soon.... SVT Kit
Posts: 3,562 |
Originally posted by CoNtOuR98: OK I finally figured out how to get the power steering thing out and took out my computer. So I started cleaning the pins when I noticed that the little sponge was completely worn, and was not doing anything anymore. But the thing is half of the pins were copper color and other half was silver. What color should they be? I called superchips and they told me it should be copper, and on the instruction sheet it says silver? Anyways for right now he's sending me some more sponges to clean the contacts. Oh by the way I did try it and the car wont start. So either wrong code or dirty contacts. Thank you Most likely dirty contacts. Silver or copper, doean't matter as long as it's a clean metal contact on all pins. I actually had to use a small plastic scraper to get the job done... and a little carb cleaner on a rag to wipe away the residue. HTH.
Brad Noon '99 SE MTX 3 point oh my God H.O. 179HP/178TQ BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!bnmotorsports@msn.com
Posts: 1,041 |
The contacts may also not be contacting enough with the computer. Mine went out on me, my car just died on the road. I took out the chip and worked just fine. After talking to Superchips we found out i needed some soder on the tips to make a better contact.
Silver 98 SVT Contour E0 #4124 (Currently on Life Support) Built 11/97 Bought 1/98 Eibach Pro Kit \ Koni \ Niche Pultec 17"x7.5 \ Yokohama Parada 215/17/40 \ Shaved Wheel wells / Brembo-KVR Cross Drilled Rotors / KVR Carbon Fibre Brake Pads / Aeroquip SS Brake Lines \ 21mm Rear Progress Tech. (Powder Coated Black) \ Superchips Auto Meter Pro Shift Light \ Extrude Honed \ Stripped Resonater Street Scene Free Flow Exhaust \ Injen Technology Prototype CAI \ Weapon R filter \ Hose Techniques Red Kit \ Folia Tec Red Caliper Paint \ MOMO (shift knob, pedals, seat belt pads) \ Clarion, Sounstream, Kicker \ Optima Red Top Battery \ SVT Emblem Mods Jet Hot Coatings (25-30% Cooler) on Upper Intake Manifold, Sho Shop Y-Pipe, Cat, and CAI "Come Out...Come Out Where Ever You Are" http://www.geocities.com/speeddemons19
Administrator
Administrator
Posts: 5,037 |
Try this, Put the chip on and off a few times. This will "cut" into the card edge contacts. Look and see the shiney metal grooves it leaves behind. It sounds like you have done a good job cleaning. One side might have copper and the other side might have aluminum for trace. Just slap it on and go!!
