#1303595 06/13/05 02:18 AM
I put in a gauge cluster w/ tach, to replace my non tach gauge. I hooked up a wire to the ECU pin 53, or something like that; the white wire w/ the black stripe in the 3rd row. I used one of those blue snap connectors, and connected it with a length of 16 gauge wire into the instrument cluster. I just pushed it through so the wire was sticking out, since there is no pins for it, where pin 8 is. I hooked everything back into place, and the tach won't work. I have no more ideas, I tried for hours.
[color:"green"]-Matt R
'99 Tropic Green LX, Zetec, ATX
#1303596 06/13/05 06:28 PM
The plug at the back of the cluster has a removable back so you can see the wires & guts in the connector. You need to figure out a way to secure the wire in there.
I suggest finding a Contique in the local bone yard, any year/configuration will do, and pull out one of the wire/connector 'pins' and just snip off a length of the wire behind the 'pin' (for lack of a better word) and splice into that.
#1303597 06/20/05 05:48 PM
Anyone else have any ideas on making it work?
#1303598 06/20/05 05:53 PM
Keep plaing with it and make sure the car is running....
www.ChicagoCEG.com 2006 White Grand Prix
#1303599 06/20/05 06:30 PM
Too bad you aren't closer, I'd help you with that.
Seems to me I owe you some pix of the cluster...
#1303600 06/22/05 02:37 AM
Lol, I know it is hooked up okay and everything. I just think the contacts aren't what they should be. I was a bit concerned about using 16 gauge copper wiring, that wouldn't mess w/ the signal at all would it?
#1303601 06/22/05 02:43 AM
CEG road warrior
CEG road warrior
No...that is what I used.
#1303602 06/22/05 04:07 AM
Cool, ok. So does anyone have a pin they can get me? I'm getting pretty sick of looking at a dead tach.
#1303603 06/22/05 05:46 PM
I wrote a how-to on this a long time ago, and if I remember right, I mislabeled the pin number. I think it's pin 48 on the ECU connector. It is black/white. Hope this helps...
Andrew Morris '99 SE Zetec ATX All of life's big problems include the words indictment or inoperable. Everything else is small stuff.
#1303604 06/22/05 06:43 PM
I thought it was 53 or something. I know I got the right pin there, and the right pin in the back of the cluster (8), but I still think the connection in the cluster is the problem w/o the stock pin.
