#1302584 06/11/05 06:44 PM
Con-Man Offline OP
Pre 98 Con people,
Just went out and brought a corner from the salvage yard for $5.00. I wanted to pratice first. I will say this it is some work involved with this mod grind sand grind some more sand some more. I am using my drill and a adapter to get the orange out. I was about to give up until I finally started see the clear coming through words can't descibe the feeling. I will continue to work on this one once I'm done I will go to the yard and get two corners and work on them to put on the tour. This is a time consuming procedure there is no short cuts so if you need your car do not pull your corners off and think you'll get this done in a weekend. Keep yours on your car and buy another pair to work on. I did a search on clear corners and I read about that secret reflective material that one of the guy's put in there corner does anyone know what that material is yet?
2006 Mustang GT 2004 Mustang GT (Gone) 2004 Yamaha FZ1 1995 Contour GL 1982 Cutlass 2 door
#1302585 06/11/05 08:31 PM
9
Originally posted by Con-Man:
Pre 98 Con people,
....with a dremel i had both corners done in about 7 hours..so i'm gonna disagree with you about it being a weekend job...but it is def a full day worth,after the silicone drying and whatnot...and also it's a 5 foot mod..anycloser than that and it starts to show the "homemadeness" of the mod..i took them out and bought some mondeo corners,just require some body filler on the fenders
#1302586 06/11/05 09:17 PM
Con-Man Offline OP
tour96,
It will be more then a weekend for me because I don't have a straight 7 hours at once to give to this project. Most people don't that's why I recommended that if you want to do this mod don't pull out the corners your using get another set and work on them alittle at a time. So you did 7 hours worth of work and when it was all said and done it wasn't worth it? Maybe I'll stop now.
#1302587 06/11/05 11:43 PM
9
no, its cool, it just takes time...you have to take your time becuase if the lenses get to hot they will crack and yellow...i have a couple of pics of you go to the registry and type in tour96se...they're not close ups but you can tell that they are clear...
#1302588 06/12/05 03:41 AM
i know this had been answered somewhere at sometime, i cant find it. trying to take off my headlight lamp, i can locate two screws that are suppose to come off, but cant find the third one. i got the two lower ones. there is a metal arm, is it located behind there somewhere or what. and if you happened to have a pic with the pointed out screws even better. thanks.
#1302589 06/12/05 07:06 AM
Con-Man Offline OP
click on search at the top of the page when you get there you'll see.
Forum or Category to search
click on troubleshooting
next you'll see
Words to search for
type in remove headlight
next you'll see
Search options
leave it at Entire Phrase
next you'll see
Date Range
click on all post
then select submit your answer will come up. There is alot of knowledge on this site you just have to look for it.
