#1302364 06/11/05 03:37 AM
I
I
Hey Guys,
I found the solution of my A/C. It is the compressor that always on and not cycling. If you believe the Haynes Tech book, I need to replace the cycling switch.
My question is: Do you have to discharge the AC/C to replace the cycling switch ?
Zetec MTX 96.
http://www.carplugs.com/
Thanks,
Intravino
www.carplugs.com OBD2 Scantools OBD2 Cables OBD2 Connectors OBD2 Free Software
no, you do not need to drain the A/C. Just unscrew the switch, it has a protective (shrader Valve) looks the same as your tire valve for putting air in your tires.You wont loose any gas.
I
I
Thanks,
