Hey I noticed at the wrecking yard that the Cougar and contour gauge clusters are similarly shaped and have a similar bolt pattern. The wiring plug is different. The cougar gauges look much better then the contour ones do. Anyone have the wiring schematics for a cougar gauge cluster or a contour one? The cougar ones are digital for the odometer, so not sure how that could be fixed to be accurate.
ATX MTX swap, rear drum disc swap, drilled rotors, ported intake, optim throttle body, CAI, 7.5L MAF, adj. fuel regulator, longtube headers, underdrive pulley, no EGR, low inpedence bigger injectors, 2002 Focus Swap
