Posts: 19 |
I'm in a desperate need to change my oil pan gasket (It leaks all the way around it). Now I know that I need a cherry picker to hoist the engine up, but do I need to take off all of the engine mounts and take the bolts that connect it to the Fly Wheel. I would appreciate a responce ASAP. Thanks Paul.
Paul Bobadilla
1998 Ford Contour SE Sport
V6 2.5 Duratec
Posts: 5,600 |
correct me if i am wrong, but i thought you only had to remove the y-pipe to remove the pan (no picker necessary)
Black 1998.5 CSVT
Posts: 6,700 |
Thats what I thought, too.
2006 Pontiac G6 3900SFI GTP Coupe
CAI, Stainless Cat Back, Vector Tune, Strut Brace, Eibach Pro Kit, Custom Made Projector Headlights, 4300K, 20% Tint
Former Owner- 2000 "Stryped" CSVT
CEG Dragon Run- Oct 13-15
Posts: 4,270 |
That's all you do have to do, i was under the tour a few days ago, all you need to do is drop the y-pipe then you can drop the pan, you don't need to pull the motor
~Alex
Ex- SVT Driver627
MUST SELL!!!LOCAL:
Pre-98 MOLDED trunk
Polk db speakers
Corolla parts
LED Underbody Kit
PM
2000 Green CSVT gone on 2/17/06
2001 Toyota Corolla (SHE RUNS!!!)
1989 Mustang LX 5.0
Posts: 5,600 |
i dont think he meant pull it, but basically support it while some weight bearing support was removed underneath. in either case, its not necessary.
Black 1998.5 CSVT
Posts: 19 |
For some reason on mine I have a suspension piece going across the right side side of the pan. The pan would hit it if I tried to lower it.
Paul Bobadilla
V6 2.5 Duratec
Posts: 540 |
It will come out the bottom. All you have to do is remove the y-pipe. The sub-frame does not prevent you from doing this - it only it makes it difficult to torque the screws properly, but it can still be done.
'98 SVT Red/midnight blue - a few mods
E0 wheels for sale - PM me
Posts: 5,600 |
Originally posted by Chef Paul: For some reason on mine I have a suspension piece going across the right side side of the pan. The pan would hit it if I tried to lower it.
that is the subframe. the only thing that gets in the way of is removing the bolts. once you get the bolts out, you can slide the pan forward and out of the way of the subframe.
the bolts CAN be reached even with the subframe in the way. just have patience, you can do it.
Black 1998.5 CSVT
Posts: 4,270 |
patience is a virtue, you will learn this quite a bit with these cars.
~Alex
Ex- SVT Driver627
MUST SELL!!!LOCAL:
Pre-98 MOLDED trunk
Polk db speakers
Corolla parts
LED Underbody Kit
PM
1989 Mustang LX 5.0
Posts: 19 |
Thanks for the info. It will help alot
Paul Bobadilla
V6 2.5 Duratec
