"You can see the linkage and vacuum motor on a 95 by looking under the manifold."
I know it's under there....just can't see it with everything in place.
"The front side opening, by the water pump, has the linkage for the front butterfly array. I can stick my fingers in there and move them. When the engine is running I can see mine open/close when I snap the throttle wide open."
I'll try that.
"When you push the car hard does it miss or hold back in higher gears and RPMs?"
Nope....in fact, once the secondaries kick in, it seems to pretty much smooth out.
"Does it knock even with the Techron in the tank? "
Never has knocked to begin with.
"I guessing the fuel pressure is low which can be caused by a bad pump or dirty filter(s)."
Forgot to have the fuel pressure tested when I brought it in for the diagnostic
But, I did replace the fuel filter...obviously doesn't help if the pump is having issues though.
