Posts: 5 |
My wifes 98 contour GL 2.0 Ztech started blowing warmer than normal air from the vents in both normal and MAX A/C. I checked the pressures low side 48PSI and high side 290PSI. I noticed the compressor is not cycling, It stays engaged constantly when in either A/C setting. does anyone know if this vehicle's A/C compressor is supposed to cycle? I have read that some A/C systems use a variable displacment pump or other restrictions in liew of a cycling clutch. I thought every newer A/C system used the cycling clutch. My 97 escort does. thanks in advance.
Posts: 392 |
I'm not sure but I think that your high pressure is too high.
The compressor is suppose to cycle, it's not normal to be constantly engage.
Nic.
Contour 99 MTX V6 fully loaded, stock with 110000km. Illuminated sunroof switch. About to do the mystique rear dome light conversion with eyeball dome light.
Posts: 7,100 |
PINPOINT TEST A: THE A/C DOES NOT OPERATE/DOES NOT OPERATE PROPERLY A1: CHECK THE OPERATION OF THE A/C COMPRESSOR CLUTCH A2: CHECK FOR MECHANICAL ERRORS A3: CHECK THE A/C CYCLING SWITCH A4: CHECK THE REFRIGERANT SYSTEM PRESSURE A5: CHECK FOR VOLTAGE AT THE A/C CYCLING SWITCH - CIRCUIT 14S-CA17 (VT/OG) A6: CHECK FOR VOLTAGE TO THE DUAL PRESSURE SWITCH - CIRCUIT 15S-FA38 (GN/RD) A7: CHECK THE DUAL PRESSURE SWITCH A8: CHECK CIRCUIT 15S-RE9 OR 15S-RE9A (GN/BU) A9: CHECK THE A/C CYCLING SWITCH C692 FOR OPEN A10: CHECK CIRCUIT 15-FA12 (GN/BU) FOR VOLTAGE A11: CHECK CIRCUIT 15-FA11 (GN/YE) FOR OPEN - PCM CONNECTED A12: CHECK THE CIRCUIT 15-FA11 (GN/YE) FOR OPEN A13: CHECK THE CIRCUIT 91S-FA11 (BK/YE) FOR OPEN A14: CHECK THE A/C WOT RELAY A15: CHECK THE VOLTAGE TO THE A/C CLUTCH SOLENOID - CIRCUIT 14S-CA6 (VT/YE) A16: CHECK THE VOLTAGE TO THE A/C COMPRESSOR CLUTCH DIODE - CIRCUIT 14S-CA7 (VT/BU) A17: CHECK THE A/C COMPRESSOR CLUTCH DIODE GROUND FOR OPEN - CIRCUIT 31-CA7 (BK) A18: CHECK THE A/C COMPRESSOR CLUTCH DIODE A19: CHECK CIRCUIT 31-CA6 (BK) FOR OPEN A20: CHECK THE AIR DISTRIBUTION CONTROL SWITCH FOR VOLTAGE - CIRCUIT 15S-FA13 (GN/RD) A21: CHECK CIRCUITS 15S-FA17, 15S-FA17A (GN/OG) OR 14S-CA17 (VT/OG) FOR OPEN A22: CHECK CIRCUITS 15S-FA13 (GN/RD) FOR OPEN
Step A4 states that if the pressure is higher than 50PSI on the high side (after A1 A2 and A3 are verified to be in working order) then replace the A/C Cycling switch, as seen below:
Connect gauge set to port. High side reading must be above 169 kPa (50 psi).
l Is the high side pressure above 169 kPa (50 psi)?
�¨ Yes INSTALL a new A/C cycling switch. TEST the system for normal operation.
�¨ No CHECK and REPAIR the refrigerant system for leaks or low charge or incorrect A/C compressor clutch air gap. TEST the system for normal operation.
I know there are a ton of tests on that list, but I will be ready to elaborate more on any tests you come to, if need be.
Ray
'99 CSVT - Silver #222/276
Posts: 5 |
thank's for the valuable diagnostic check list. I will start sorting out the problem shortly starting with the most likely. Thanks Again for the help.
Dean
Posts: 2,163 |
How much should all of this cost Ray
"PINPOINT TEST A: THE A/C DOES NOT OPERATE/DOES NOT OPERATE PROPERLY A1: CHECK THE OPERATION OF THE A/C COMPRESSOR CLUTCH A2: CHECK FOR MECHANICAL ERRORS A3: CHECK THE A/C CYCLING SWITCH A4: CHECK THE REFRIGERANT SYSTEM PRESSURE A5: CHECK FOR VOLTAGE AT THE A/C CYCLING SWITCH - CIRCUIT 14S-CA17 (VT/OG) A6: CHECK FOR VOLTAGE TO THE DUAL PRESSURE SWITCH - CIRCUIT 15S-FA38 (GN/RD) A7: CHECK THE DUAL PRESSURE SWITCH A8: CHECK CIRCUIT 15S-RE9 OR 15S-RE9A (GN/BU) A9: CHECK THE A/C CYCLING SWITCH C692 FOR OPEN A10: CHECK CIRCUIT 15-FA12 (GN/BU) FOR VOLTAGE A11: CHECK CIRCUIT 15-FA11 (GN/YE) FOR OPEN - PCM CONNECTED A12: CHECK THE CIRCUIT 15-FA11 (GN/YE) FOR OPEN A13: CHECK THE CIRCUIT 91S-FA11 (BK/YE) FOR OPEN A14: CHECK THE A/C WOT RELAY A15: CHECK THE VOLTAGE TO THE A/C CLUTCH SOLENOID - CIRCUIT 14S-CA6 (VT/YE) A16: CHECK THE VOLTAGE TO THE A/C COMPRESSOR CLUTCH DIODE - CIRCUIT 14S-CA7 (VT/BU) A17: CHECK THE A/C COMPRESSOR CLUTCH DIODE GROUND FOR OPEN - CIRCUIT 31-CA7 (BK) A18: CHECK THE A/C COMPRESSOR CLUTCH DIODE A19: CHECK CIRCUIT 31-CA6 (BK) FOR OPEN A20: CHECK THE AIR DISTRIBUTION CONTROL SWITCH FOR VOLTAGE - CIRCUIT 15S-FA13 (GN/RD) A21: CHECK CIRCUITS 15S-FA17, 15S-FA17A (GN/OG) OR 14S-CA17 (VT/OG) FOR OPEN A22: CHECK CIRCUITS 15S-FA13 (GN/RD) FOR OPEN
�¨ Yes
�¨ No
Ray "
Posts: 2,408 |
Originally posted by Mr. Kamen: My wifes 98 contour GL 2.0 Ztech started blowing warmer than normal air from the vents in both normal and MAX A/C. I checked the pressures low side 48PSI and high side 290PSI. I noticed the compressor is not cycling
Both pressures are high, this would normally indicate that freon was put in the system when not needed (for instance because the temperature air door quit closing completely causing some heat).
And yes, it won't cycle if the low side stays above about 27 psi.
