Posts: 1,682 |
anyone know pros/cons on doing this to the svt? and what is available? if anything...
Posts: 3,562 |
Originally posted by bret: anyone know pros/cons on doing this to the svt? and what is available? if anything... The SVT shouldn't need a shorter gear ratio as it already has problems hooking up with anything short of a Quiafe installed. Shorter gears would compound this problem. What we need are Euro spec gear box (closer ratio) with the US spec final drive diff gears. This is the combo Mumm Bros have run in their Cougar... they say it should tear up the streets... To my knowledge, nobody has attempted this for the street... yet... The only other way is to simply put shorter tires on your car...
Brad Noon '99 SE MTX 3 point oh my God H.O. 179HP/178TQ BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!bnmotorsports@msn.com
Posts: 1,682 |
how much does the euro spec gearbox cost? where can i get it?
Posts: 1,682 |
i have a quaife... so would it be worth it to get a shorter gear?
Posts: 59 |
Is it possible just to order the eurospec input and output shafts? Terry A little help here!
Posts: 669 |
This guy I work with says his cousin with a CSVT put some different gears in his car. I say that his cousin is smoking crack and this guy is too for believing him. I was thinking maybe the SVT has different gears from other Contours and that could have been what he meant. Is this true or am I the one that is smoking crack now??
'99 SVT Contour 1298 of 2760
Administrator
Administrator
Posts: 4,527 |
bret, what are you hoping to accomplish w/ shorter gearing?
It's all about balance.
bcphillips@peoplepc.com
Posts: 3,562 |
Originally posted by bret: how much does the euro spec gearbox cost? where can i get it? Ask monkeyra or indy jones... they are over there somewhere... Probably a bit expensive... Mumm Bros may be able to help you, Barry is very helpful to talk to.
Posts: 1,682 |
Originally posted by Rara: bret, what are you hoping to accomplish w/ shorter gearing? well, with the quaife, shorter gearing, sticky tires (maybe d/r) i am hoping to get better acceleration, then have a custom burnt chip to bump up my redline enough to still stay in 3rd on the 1/4 mile... anyone got one of those rpm/speed calcs for different gearing and tires?
Administrator
Administrator
Posts: 4,527 |
as it is you have to bump the rev limiter to stay in 3rd for the 1/4, I don't think you will be able to spin the motor fast enough (at least not w/ out parts flying out randomly) to stay in 3rd if you drop the final drive gear lower by any noticable amount. I really think your efforts are better spent elsewhere as far as gaining 1/4 mile times. Besides, shorter gearing will increase the torque seen at the half-shafts by quite a bit, and they are overtaxed already by either a 3L or an S/C, the shock loads would likely be too high for them to last. btw, even if parts were readily available to do this swap, it would be very expensive for not a very large gain. Now on a Mustang, that's a different story entirely
