Posts: 156 |
I have seen recent posts regarding the current fad of "locking" the secondaries open. It seems that most agree that ideally the secondaries should remain closed off the line, but should open much earlier than the stock ECU calls for. My understanding is that the Superchip reprograms for a 3100 RPM opening. But many have stated that this may even be a bit "late". I am having a Superchip custom programmed and thus I can specify a particular RPM for the IMRC to open the secondary intake runners. I would like to get everyone's thoughts on this issue as to what RPM to specify. Please keep in mind that I do have a KKM, 75mm Pro-Flo MAF, SHO-Shop Y-Pipe, hi-flow cat, Bassani cat-back, and SHO-Shop pulleys. I will probably upgrade the throttle body if I can get some conclusive results on the Mustang TB changeover or if there is an aftermarket unit. Thanks for the input guys.
Matt
2000 Toreador Red SVT All Mods Except Vortech Quaife HP Clutch Light Flywheel
Posts: 265 |
Posts: 1,682 |
i can get an eec tuner, and do a series of dyno runs to find the best time to open them at, if you would like...
Posts: 156 |
If you're willing to do that Bret, that would be very cool of you. It sounds like a lot of trouble, but I'd certainly appreciate it. Let me know. Thanks.
Matt
Posts: 1,847 |
yeah, let all of us know, so we can get superchips programmed the right way.
95 Contour SE ATX V6 "Cracked" Secondaries DMD Installed SVT Brakes
Administrator
Administrator
Posts: 702 |
It is probably sweetest in the 2800-2900 range. I can sure feel a difference with the superchip -- much smoother rpm build through 3K-4K. If only it didn't detonate so badly at 4300+ rpm.
-Lance
Lance Kinley CEG Webmaster 95SE, "Official CEG Beater" Quaife, SVT parts, ST200 wheels, SS Y-pipe I perceive you to be a stand-up, rational individual...
Posts: 3,598 |
Somewhere between 2700-2900.... Do two dyno pulls, one with them pinned and one stock. Just find where the "pinned" setup starts gaining power over stock and you've got your ideal rpms....
\'94 Cobra #4963/5009, black on black, not quite stock Formerly owned a black '00 SVT, #1972 Join the SVTOA! RIP - Ray "Old Fart Emeritus" McNairy
Posts: 2,025 |
Originally posted by lkinley: It is probably sweetest in the 2800-2900 range. I can sure feel a difference with the superchip -- much smoother rpm build through 3K-4K. If only it didn't detonate so badly at 4300+ rpm.
-Lance Yeah, that was my problem when I got my Superchip...code SFG0. Nice to have the Secondaries open up early...sucked that it detonated at higher rpms...even with Sunoco 94.
1998 SVT Contour E1, Black 2001 Honda SuperHawk VTR1000F "I bent my Wookie" www.mamisano.com
Posts: 39 |
Your combined use of the Superchip AND an aftermarket Mass Air meter is probably causing a lean condition where the detonation starts. When running a custom chip with an aftermarket MAF, you really need to check your A/F ratio with a wide-band O2 system.
Wife's car: '98 Contour SVT, black, drop-in K&N, no reasonator w/stock mufflers, Optima red top gel cell battery #0703 of #6535 My car: '95 Mustang GT, teal/gray cloth, w/Saleen body kit, 13" Baer brakes, GT-40 intake, Edelbrock heads, stock cam w/1.7 RR, 75mm Pro-M, 36lb injectors, custom JMS chip, MAC longtube headers, Vortech S-Trim (6-7psi), and way too many more mods to list... 382rwhp 379ftlbs torque with a very mild tune from JMS Visit www.sn95.com
