Posts: 249 |
Will springs from a 95-97 Mystique fit on a 96 Contour? I found a new, more affordable lowering spring in JC Whitney today, but they only list it for 95-97 Mystiques. The whole set was like $79 and they're supposed to give a 1"-1.5" drop...
Thanks in advance... -BigC
There's a difference between a Euro and a Ricer...
Don't cross the line...
Anything-Goes C.C.
Co-Founder
Posts: 1,444 |
The dash in 95-97 means 95 through 97. for exmaple if it said 1900-2000, it would include all of the years between 1900 and 2000. so, to answer your question, yes.
Posts: 249 |
Thank you for that useless post.
The problem was not in relation to the years. I wanted to know if Mystique springs fit the Contour.
Thanks for pointing out that 96 is between 95-97. I never would have guessed.
It listed the MYSTIQUE. Not the CONTOUR. That led me to believe that the two had different springs.
Will 95-97 Mystique springs fit a 96 CONTOUR?
Thanks again- BigC
Anything-Goes C.C.
Co-Founder
Posts: 3,065 |
Lol that was pretty stupid batmobile. I don't think there is any difference, should work ok.
BTW, you must have not searched very hard, because i found this in one second:
linky
Posts: 246 |
"Thanks for pointing out that 96 is between 95-97. I never would have guessed."
I guess I am pretty bored cause I'm LOL
'00 CSVT Koni/B&G (New), SCA intake, 18 inch Falken Circuit Spec (gunmetal), CF hood, Headlights by Dan, Mirko, deleted front license plate/painted chrome ring. Headers/y pipe installed - TruBendz Borla system no Res and optimized TB. Getting there!
Posts: 2,086 |
Yes they will fit, all model/years springs from any contique will fit on all contiques.
Edit: I also found the springs he is looking at does anybody know anything about the springs, cuz I'm in need of new suspension springs and also, it lists them as front suspension springs couldn't I also use them for the rear too?
Jason G.
Born: 11/96
Posts: 21,197 |
Originally posted by BigC: Will springs from a 95-97 Mystique fit on a 96 Contour? I found a new, more affordable lowering spring in JC Whitney today, but they only list it for 95-97 Mystiques. The whole set was like $79 and they're supposed to give a 1"-1.5" drop...
Umm that's 79 per pair. $160 total! You're going to need a performance strut as well. Great CEG has dwindled down to teenagers modifying their cars for a nickle. Anyone buying parts from JCWhitney needs a serious head exam. Get the BAT or Koni kit $600. Anything less and you'll be spending more in the long run because you'll need new struts in a year. If you can't afford to do it right, don't do it at all!
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 2,007 |
Plus the BAT springs have a red coating, they'll match your car.
1998 Mystique LS:
-2.5 Duratec ATX
-Vibrant White
=Pics=
=Info=
Posts: 10,015 |
You've got to be kidding me! You've been here how long...and you still don't realise that the Mystique is a rebadged Contour?? Jesus people, lets use our effen brains here!
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 6,760 |
Stazi, next your gonna tell me the Sable and Taurus are the same. Or that the Cougar and T-Bird are the same. Get the funk outta here! :-)
Ryan
Trollin!
