Posts: 4,141 |
wondering if anyone has any experience with interior paints and dies for car interiors, i'm looking to make some changes, and i'm looking for the best tool for the job.
thanks pole
Totaled 02/12/06
Born 3/24/99 Reborn 3/18/06
Posts: 225 |
what surfaces and materials are you looking at doing?
99 csvt
68 cuda fastback 340
00 gp gtp (wife)
01 gs500
Posts: 4,141 |
Totaled 02/12/06
Posts: 3,195 |
The are good grades of interior paint at autobody supply shops...you have to use flex agent on any kind of plastic. This is the best paint to use, but it is still prone to scratching & chipping easily.
The panels you are painting must be thoroughly cleaned (I can't stress this enough)... any armor-all residue can really screw up a decent paint job
1999 Sportage 4x4...don't go there, it was free
....______o_o
.../_l l__\____\
..|--l l__----[]\|/[]
.....................oo
=( )_)----( )_)--)_)
Posts: 225 |
the plastic stuff is pretty easy. like svzetec said though be sure it is clean. and i have found that it helps to give the pieces a slight brush down with some fine grit paper before also. as far as the paint goes, i have had no problems whatsoever using the duplicolor paint and clear. that is if you are looking to use rattle cans and not a gun setup. there are some pics on here of mine when it was partially done if you want to look.
99 csvt
00 gp gtp (wife)
01 gs500
Posts: 2,857 |
depending on the color you want you should try krylon fusion paint for plastic...if you get a glossy color you won't need a clear...i just painted my trim with nickel shimmer its a great silver/gray color....i also sanded mine down a bit and used a coat of primer,and they turned out great....that fusion paint really hardens up and bonds to the plastic after a few days
new,new ride!
'99 svt
black/mnb
'95 mustang gt sold!
'98 svt #800 sold!
Posts: 2,571 |
i did my center console,a & b pillar,the door switch bezels,and the instrument bezel with dupli color color changing paint and that was over a year ago and they are still great, i have used krylon fusion for exterior parts and some interior on a friends and its awsome.....
Posts: 4,141 |
i'm going to experiment with satin black krylon fusions tomorrow or tuesday
i'll let you know how it works out, i'm going t otry it on an extra pannel i have before i spray my entire interior
i am worried aobut odor......
Totaled 02/12/06
Posts: 79 |
I used blue Krylon Fusion on both of my front door panels and after a good 4 hours its still tacky on the vinyl  It's probably just the humidity Maybe some clearcoat might make it harder  ...
Posts: 4,141 |
Originally posted by CoolBlackSE99: I used blue Krylon Fusion on both of my front door panels and after a good 4 hours its still tacky on the vinyl
why would you put krylon fusions(for plastic) on vinyl thats what vinyl dye is for
Totaled 02/12/06
