#98220 06/09/01 02:21 AM
gojo Offline OP
I'm in the process of gutting er replacing my precats on my 96 Se contour. I about have the front one dropped out. It looks like this one could be a challenge. The rear one is no problem. I read a little on other people who have done this, but could use a little more input.
96 Contour SE 2.5
K&N drop in
F
F
1) Go to HomeDepot and buy a matching Tap/Drill Bit. The drill bit should be big enough to accomodate a VERY long probe (3/8" drive extention will work).
2) Drill a hole in the bottom of the precat directly below the Catalytic Converter eliment, as close to the middle as possible.
3) Insert a long screw driver and begin to break up the Cat eliment ... this may require the use of a hammer and some time
4) DON'T breath that crap in ... once it is all out, thread the hole with the Tap and then plug it with a matching size bolt.
5) So that you don't have a bolt protruding into your canister, um I mean catalytic converter, note the thickness of the cat's metal shell and cut the bolt down to size.
6) Torqu down the bolt and have it welded later
7) Put back on car if you took it off and start up the car without the Y-Pipe on to "clear out" any left over debre (sp?) ... Rev the engine quite a bit for as long as the neighbors can stand it smile
8) bolt up the Y-Pipe and take her for a spin ... dont' forget to unplug the battery while doing this so that the ECU is reset.
9) Enjoy your new found power smile
Best Regards,
Trevor Cole
New Edge Cougar Forums
don't forget mil eliminators
98 silver frost SVT
custom built intake, offroad y-pipe,mystery mod,remote optimizer,short shifter,zex nitrous, lots of stereo, 17 konigs
with paradas.(bent) TOTALED do to freak electrical fire?(that started at a wireing harness ford neglected to tell me should have been recalled as they did with the 95se) I miss this car.
NEW PROFFESSION AS A TROLL.
new car. 2000 dodge dakota 4.7l v8. custombuilt intake, custom exhaust, kennebell pcm, and electric fan conversion, 180 stat, 3.55 pegleg, my old stereo system, 17x7 billets and 255-50 nitto 450 tires. next drop and traction adders. g-tech 14.5
in search of 95 se fivespeed to hang contourparts on.
