(summary at end) ok, this problem has been going on now for about a month. the passenger side pads are dragging the rotor, not only when turning right now, but also when taking off from a light. i have replaced three rotors in the last month, three calipers, two sets of pads. i also have a new brake hose on the passenger side (the side that is the problem). now, after bleeding brakes for about thirty minutes, the pedal has to be pressed all the way in, and then when i hit it again, it gives the actual pedal pressure. this is really causing a lot of problems, the car is dragging to the right when the wheels are turned right.
brakes drag when turning to right
new EVERYTHING
bled properly
want to know what i can do
