whoohoo
im now noticing a pretty audiable vacuum leak(pretty sure)- even inside the cabin.
i briefly tried to isolate where its coming from, and it was not successfull. than i tried listening around a bit with a piece of hose as stethascope also with no avail. im starting to wonder if it would be leaking from where the PCV valve plugs in.
im beginning to "think" i remember the gasket being kind of hardened maybe, and loose.
Would a PCV valve gasket cause good noise if it was leaking, and also cause my symptoms?
I also have to report an additional issue? - when accelerating fairly fast, when its in the top of 1st gear i notice the battery light come flickering on for a second...
only happens that ive noticed in the end of 1st, when its winding out right before it shifts.
wonder what this could mean?
