Posts: 133 |
Antone got any idea's how to get the alternator pulley off ?  I've broken one "Boa Constrictor" tool thing already
ST24 Mondeo, 19's, Koni/GC coilovers, Morrette headlights, bespoke interior etc etc
Posts: 10,015 |
Heat JUSt the pulley up with a propane torach so it gets nice and hot, but not too hot, then as it cools spray on some PB Blaster or liquid wrench around the journal so it loosen it up, then pull it off with a bearing-type puller.
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
Posts: 21,197 |
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 718 |
lol...i dont know if there was something wrong with mine or what but when i put my underdrive alt pulley on the stock one came right on off...
1999 Cougar V6 MTX
SVT UIM/LIM/65mm TB, I/H/E, Fidanza/SPEC III/Torsen, Koni/GC's, 19" Icon wheels w/ Pirelli rubber, NX Wet Kit
Posts: 644 |
Originally posted by PEWTNERST24: Antone got any idea's how to get the alternator pulley off ?
Jam something through the holes in the pulley (like screwdriver, etc. - I'm guessing you won't be re-using the alt!) and into the alt. to hold it in place, then just use a regular breaker bar to loosen the bolt. Pretty straightforward actually.
1999 Red / Tan SVT
#1969 of 2760
Built 4/21/99
K&N, DMD, FMS Wires, ES Insert / Bushings, PF End Links
17" FSVT 5-Spokes
Factory Spoiler
35% Tint All Around
Posts: 133 |
Originally posted by delmar: Originally posted by PEWTNERST24: Antone got any idea's how to get the alternator pulley off ?
There are no holes in the altternator pulley but do you think maybe i could drill a hole in to get a scrwedriver in it as i dont have access to a propane torch ?
Posts: 10,015 |
I wouldn't drill it cos if it doesn't end up coming off you will be SOL as the pulley will be out of balance and it'll toast the bearing in the alternator.
Did you use an impact gun on it to reomve the nut, and liquid wrench?
BTW the mini propane torches are cheap from the local harware store, they run like $20 in the plumbing section. You should be able to find 'em in the UK too.
AUSSIE ENDLINKS $70
Posts: 133 |
I didn't use an impact gun but how can i hold the pulley to stop it from turning with the nut ?
Posts: 9,065 |
Strap wrench
Posts: 133 |
I've already broken one of those
