Posts: 94 |
Any ideas. Driver window wont roll down with the door closed but alll other functions work fine. Any other sugestions.
98 CSVT droped on 17x8 tsw rims w/kuhmo 225/45/17
svt badges on fenders svt ovals frnt&rear st200 badges rear lower door
painted calipers,reflector,chrome oval
short ram intake
pioneer deh-960 mbquart seperates PG octaneR 4ch
Posts: 1,572 |
Probably the brushes in the motor itself, you can pull it out fairly easy and rip it apart and clean it .
Check me out for awsome powder coating deals
www.powdercoatingworld.com
People shouldn't slam each other when posting, If you cant say something good to say then just hit the back arrow.
Posts: 94 |
it rolls up just fine just not down.
short ram intake
Posts: 4,693 |
Although problems with the motor or regulator are more common, test the switches before replacing anything.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 94 |
I've tested everthing i can think of to test. Wires comming out of the switch light up the tester when acording buttons are pushed. When i go down to the motor itself and poke the white wire into the motor it lights the tester when the roll up button is pushed but not the roll down button. When i poke the yellow wire into the motor it lights up the tester when the roll up button is pushed but not the roll down button. Am i missing something here?? Cant seem to track down a diagram anywhere. Any help?? I dont know exactly how a power window system is supposed to work.
short ram intake
Posts: 94 |
throw me a bone here. somebody, anybody
short ram intake
Posts: 786 |
maybe you should take off the door panel and see if you can find the problem.
Posts: 4,693 |
I'm not sure I understand how you are testing it.
Keep in mind, that the motor runs in reverse on one of the directions. It is reversed by reversing the polarity of the current going to it.
Jim Johnson
98 SVT
03 Escape Limited
CEG road warrior
CEG road warrior
Posts: 17,248 |
I had problems with my windows due to the connector (where all the wires screw into the harness in the door jamb)wasn't screwed in all the way.
Hector
257HP/259TQ
2005 Lapis Blue Mazda 6s
160HP/141TQ
