Posts: 46 |
For some reason, there is come kind of noise happening when I shift. It almost sounds like a popping sound. However, when I go real easy on the gas and shift like an old woman, i dont hear the sound as bad, or at all. I searched and couldnt find an answer to my question. Do any of you know what this could be?
1999 SVT Contour
Magnaflow Dual Exhaust
KKM High Flow Intake
Posts: 1,303 |
if when you go easy on it, it doesn't happen, my guess is that it might be a synchro going out, or gone? When that happened to me it was between 2nd and 3rd and only when driving hard.
Goonz12: <---tries on mommy's cloths
Posts: 46 |
were you hearing a grinding or like a pop? when i shift from 2nd to 3rd, if i leave it in neutral for a sec, and then shift, it doesnt pop. But if I shift fast, then i hear it. Anybody have an idea what could be going on here?
1999 SVT Contour
Posts: 5,810 |
When you say shift, are you also including engaging the clutch or are you just talking about the action of shifting into 3rd gear? I would say you could try flushing out your fluid in either case and then running some Redline MTL.
See My Mods
Posts: 46 |
I am talking about putting the car in 3rd gear while I have the cluthch in all the way. I am wanting to get the clutch replaced anyways, so do you think that replacing the clutch may solve this problem? Also, what is good clutch to look for? I still have 20k left on my warranty, so I didnt want anything that would void my warranty. Any ideas? Also, how much am I looking at spending for parts and labor for this?
Thanks, Brian
1999 SVT Contour
Posts: 46 |
Can anyone give me a rough estimate on parts and labor for that, please?
1999 SVT Contour
Posts: 21,197 |
Originally posted by OFace12: Can anyone give me a rough estimate on parts and labor for that, please?
Dealer $1200. 1k labor just for a clutch.
-'96 SE MTX 3L
-'98 SVT 1,173 of 6,535
Posts: 46 |
I have been looking in former posts and I will probably get the SPEC stage I kit. It is $329 on Spec's website. My question is, does anyone know of any other kits that I should look at? and, does anyone know if the Spec clutch would void any warranty that I have on the car? I will call Ford later today, I just wanted to get your $.02 before I did.
Oh yeah, i have read that I should have the Ford T/O bearing replaced with another Ford one. Is this true, why is that? Anything else I should look out for?
Thanks, Brian
1999 SVT Contour
Posts: 5,810 |
Dude, I've been using the spec stage 3 and the spec provided throwout for two years. I haven't had any issues. Get the Ford throwout and you'll be golden, but I just wanted to let you know that I haven't had any issues with mine.
See My Mods
Posts: 4,051 |
Originally posted by warmonger: Dude, I've been using the spec stage 3 and the spec provided throwout for two years. I haven't had any issues. Get the Ford throwout and you'll be golden, but I just wanted to let you know that I haven't had any issues with mine.
Same here. One year so far and still going strong.
Although I will say if I knew about the SPEC problems in the past, I would of just bought a Ford replacement at the time of the clutch install.
Since it's held up so far, I'm just going to keep it.
