Posts: 46 |
Hello, for some reason, i am getting some kind of popping sound from my left front wheel. And before you yell at me to search, i did. The popping is not coming when i turn or anything like that, it happens when i go over a speed bump or i am on a bumpy driveway. I want to know what this is so I can get it looked at ASAP.
1999 SVT Contour
Magnaflow Dual Exhaust
KKM High Flow Intake
Posts: 2,353 |
Possibly a broken sway bar mount? Never heard of this happening in the front, but that's what it sounds like...
1999 Blk/Tan CSVT #654 - SOLD
2003 Suzuki SV650s
Posts: 1,578 |
That very exact same thing was happening to me. It has something to do with the way the spring is sitting in the strut. I'm not sure what I did but I compressed the spring while it was in the car and fiddled around with the spring then uncompressed it and it hasn't made a noise since. Good luck with figuring that out
Alex
00 T-Red/Tan SVTC
#1964/2150
167 HP @6800
153 TQ @3000
Sold-
98 'Tour SE 24V 5-spd
149 HP @5900
148 LB FT @4300
Posts: 46 |
What do you mean when you say "fiddled around with it"? and how did u go about compressing the spring? by pushing down on the car at that corner?
Thanks, Brian
1999 SVT Contour
Posts: 9 |
I have the same problem since I put my new springs in. I got it evaluated by my brother (who is a local car technician) and he said its a blown strut. Not a bad thing, just another excuse to have better struts, although I had SVT struts in my SE.
Posts: 4,051 |
It's most likely just the spring not sitting properly.
That happened to me when I installed my springs a long time ago. I had the suspension worked on a few months after but nothing got replaced, just reassembled. The car hasn't made the noise since.
Posts: 46 |
Ok, well I will take it to Ford and have them reassemble the spring setup and see if that fixes the sound. Thanks a lot you guys. Brian
1999 SVT Contour
Posts: 375 |
Have en look at your front anti-sway bar stabilizers... their prone to wear and make one hell of a racket.
96 LX 3.0L MTX - Black/Tan
K&N; 12lb F/W & uprated clutch
2.5" Pipe; SVT bits; Mystery Mod; Pull-tie Mod;
UN-tuned Mod; 3rd Gear Synro-Crunch Mod
280K on the Shell, and 40ish on the Motor... 1/4 mile??
Yeah, it's a fun daily driver...
