I figured out why my 3l Didn't start and it was the last thing i wanted it to be. The timing is off on the rear bank of cyls. I did have the front cover off to check if the pulse wheel was on correctly but I'm not sure if I will be able to adjust the timing with the engine still in the car. Has anybody done it before? I know it says in my Haynes manual that the engine should be removed.
98.5 Black contour // A.K.A. Frankenstein
3L Oval port swap W P&P // SVT UIM, LIM, & Cams
Torsen LSD // Dual Friction // KKM // Poly Mounts // ?Mystery Mod? // Actually Running!
205 hp @ 6500RPM 180 tq @ 4250RPM
