Okay, here is my problem. 99 SVT. I should start out by saying that I have applied the moosing fix that is listed in the Common Problems FAQ. The throttle hang is definitely better, but the moosing is still there. I will also say that it only occurs after the engine has warmed up. It happens as soon as I start to let off the clutch and quits at between 5-10mph. Also the weather is quite warm (70 degrees). This doesn't sound like the problem described in the FAQ, but I figured it wouldn't hurt to try the fix. Does anyone have any other suggestions as to what could be causing this? I just recently replaced the suspension with the BAT European Handling Kit. Any help would be greatly appreciated. Thanks in advance!!
Shaun
