Posts: 62 |
I was just reading the new sport compact car and there is an article on the focus. They are installing a new clutch and a phantom grip limited slip to the diff. So I checked there website and there is one available for all contours.Just thought i would let you all know in case your interested in a cheaper way to beef up the diff instead of a quaife. Check out there website. http://www.phantomgrip.com
Kyle Pickett (Austin,TX) 98 SVT (silver) #860 of 6535 Eibachs/Konis 18" TSW SGVs-225/40/18 Sumitomos KKM intake/BAT inlet pipe KKM pedals Sho Shop pulleys B&M shifter/ATR aluminum knob mesh grilles Autometer shift lite SCA sidemarkers Hose Techniques SuperBlue hose kit Home-made rear STB
Posts: 703 |
I didnt catch anything regarding a price on there. How much are we talking for this?
Seeya FUseface "Superhero Extrordinaire" "I am Nigh-Invulnerable!" 97 LX Sport
AIM:MiguelAD8
Administrator
Administrator
Posts: 5,037 |
They are supposedly less than $200. That's what I am getting for my ATX when I start having problems with traction.
Posts: 878 |
269 at the following retailer: Rivergate
"Function before fashion."
'96 Contour SE
Posts: 4,042 |
If you have a MTX, you'd be CRAZY to buy that instead of the now 'almost cheap' Quaife, and the Torsen coming out in the fall.
Even with the Phanthom Grips, you're likely to blow out your diff if you get wheelhop.
The Phantom Grips don't replace the ailing side gears in the diff, which are the ones that break.
John
Posts: 3,562 |
Is the phantom grip as good as the Quaife? No. but it would help for the weekend warrior who will still be careful of hard launches and doesn't terrorize corners. The deciding factor should be LABOR. Both units require a complete removal of the differential. If you take you car down that far, you should really install the best... that is unless you can't afford it like me... Poor Silvie will have to wait until next time for the Quaife if ever she gets one... booo hoooo hooo, I'm going home to cry...
Brad Noon '99 SE MTX 3 point oh my God H.O. 179HP/178TQ BNMotorsports Floormats, powder coating, TB optimizing, Gutted cats, etc BNMotorsports is now the preferred distributor of Contour/SVT/Mystique Indiglo style gauges!!!bnmotorsports@msn.com
Posts: 104 |
Oh whahh, somebody call whine one one!
98 E1 99 SE to inlaws 02" Explorer
Posts: 157 |
I had my phantoms grips put on for about 5 mos. I drag raced couple of times and noticed big difference in 60 ft times . Major difference was at the autocross. So far so good no problems and went through two transmissions and this holds up fine with the grips. Probably recommended for no more than 250hp. later
99 SVT #198 Blk/blue Grizzly clutch Phantom Grips K&N open Resonator removed BAT 22mm 15.4 @89mph
