A couple monthes ago I blew up my diff - suprise suprise.
So I have spent a lot of time on here researching and looking for parts - then the amazing wait for the national back order on the Torsen LSD.
This morning I finally got the car back together. Drives and shifts smooth. Not much wheel hoop anymore. I replaced the:
Front control arms
Swaybar bushings
Strut bearings
Upgraded 1-2 and 3-4 shift forks
Sho Shop Lightened flywheel (took a couple days longer then stated, but he did good)
Sho Shop heavy duty axles (do not know that they are any different then stock, but needed new axles)
Optimized the throttle body
Filled in the front tranny mount with rubber chunks and rubber cement (tested the flex on a scale before it took 60lbs to compress after it took all of my weight without compression, just a cheap test upgrade).
So the car is finally back together
and I can put my bug away for another rainy day in the CSVT arena.
Thanks again all
Paul
