Posts: 137 |
Hey everyone, recently bought a 2000 svtc with 68000 miles on it, its going onto 70k now, Recently, over the past 2 days or so, when i turn the wheel left, a pretty loud heartbeat like noise occurs....any ideas?
2000 Black SVT Contour
Posts: 5,143 |
where exactly does it come from? if the feeling is under your feet and its coming front he driver side front wheel well or the passenger side front wheel well.. It sounds like its time for a new CV joint. Does it have a clicking noise to it?
98 Corolla LE 1.8L DOHC 1ZZFE
TEIN H.Tech Springs
Tokico HP series Struts
Short ram air intake
Tsudo Axel Back Exhaust
Posts: 137 |
the more i turn the wheel, the harder it gets, sounds just like a heart beat coming from the steering wheel
Posts: 5,143 |
Wheel bearing or CV joint... Only two I can think of at this point. More likely a Wheel bearing if its not a ticking noise.
TEIN H.Tech Springs
Posts: 4,693 |
Is this while the car is moving or do you get it just from turning the wheel while the car is stationary?
Jim Johnson
98 SVT
03 Escape Limited
Posts: 137 |
just while the car is in motion, and just turning the wheel left. Sounds likes it coming out of the dash, a very loud heartbeat that gets faster the faster i step on the gas
Posts: 87 |
You could have a tire with tread separation causing a bubble on the sidewall. When you turn into that side, especially if the tire pressure is low, you might get that sound.
99 csvt
amazon green/tan
pre-98 sail panels
pioneer sound
72K mi
Posts: 4,693 |
A bad CV joint will make a clicking noise on turns, especially slow turns. The noise will be from the opposite side from the direction you are turning.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 137 |
i have been thinking it sounds an awful like a tire, doesnt sound like its coming from the tire though. but ill check it out.
Posts: 10,015 |
Terry Haines sent me this: Quote:
Better tell the guy that if he feels the steering wheel 'kicking' on turns chances are(99% of the time),that he has a chipped or missing tooth on the diff gear...in which case I'd book the tow truck now!!!
#1 for Bendix Brakes Kits!
AUSSIE ENDLINKS $70
Gutted pre-cats $80/set
