Posts: 1,593 |
I drained and filled my MTX-75 tranny last weekend. I refilled with Redline MTL. I was surprised that the tranny took the full 3 quarts. The "How-to" led me to believe that it would only take 2.7 quarts. I realize that each of my quarts might have been a little light, but I am concerned. Did I over fill? Is that even possible? Should I continue to fill until new fluid comes back out?
BTW, after the Redline MTL worked in if shifts really nice. Feels nice and smooth, like "Butta". Much improved.
MUST SELL - ECM computer new for a 98 V6 mtx + pats
Now trolling in a Red Nissan 4 x 4
Posts: 4,714 |
If you filled on a relatively level surface you should be ok. I also seemed to get the full three quarts in, but there was some spillage and whatnot that would probably add up to .3 quarts, plus my garage isn't perfectly level. I wouldn't worry too much.
Beer is my Gatorade.
Hooray Beer.
'98 "Sport" Pacific Green
'98 E0 SVT Silver Frost
Pictures
Posts: 610 |
as long as it isnt coming out of the hole in a stream and u just put the plug back in while the river flows then ur fine
2002 Cougar
2.5 duratec/ mtx-75
85,0000
Mondeo ST-200 wheels/BFG KDW NT
black/black
Spec Stage 1
Torsen T-2
Trubendz 2.5 flowmaster dual exaust
apexi s-afc II
K&N FIPK
Posts: 1,593 |
Originally posted by ContourGuy9817: as long as it isnt coming out of the hole in a stream and u just put the plug back in while the river flows then ur fine
That was what I was expecting, but the full 3 quarts went in. I had zero spillage, maybe a little left in the funnel... My concern is whether I need to add additional fluid, until it is full and does come back out the fill plug hole?
It was relatively level, not perfectly. If anything it sloped from front to back (rear being lower).
Posts: 638 |
Originally posted by mean'tour: If anything it sloped from front to back (rear being lower).
That's why it all went in fine without any spillage, overflow, etc... but anyway you're fine, no need to worry about it.
87 Mustang GT 5.0L TURBO
Posts: 1,593 |
Originally posted by Pope: Originally posted by mean'tour: If anything it sloped from front to back (rear being lower).
Makes sense. I hadn't thought of that, because it was approximately level. But what you say makes sense.
It's not overfilled right?
Posts: 4,693 |
It's fill 'til it spills when LEVEL. If in doubt, get it level and remove the fill plug and allow any overage to spill out.
I usually can't get the whole 3 quarts in, but I have never had any trouble with nearly three quarts. I'm sure that I have been putting more than 2.7.
Jim Johnson
98 SVT
03 Escape Limited
Posts: 10 |
In my case, it took just over 2 quarts.....and I figured the 2.7 listed capacity was compensating for the amount left on my garage floor, and all over my hands and arms! It was my first transaxle fluid change, and I had a little trouble working the hand pump while lying on my back under the car
Posts: 4,714 |
Originally posted by bribomn: In my case, it took just over 2 quarts.....and I figured the 2.7 listed capacity was compensating for the amount left on my garage floor, and all over my hands and arms!
Revised MTX-75 transaxles only require 2.1 quarts.
Hooray Beer.
Pictures
Posts: 453 |
Originally posted by hetfield: Originally posted by bribomn: In my case, it took just over 2 quarts.....and I figured the 2.7 listed capacity was compensating for the amount left on my garage floor, and all over my hands and arms!
So, which tours have the revised mtx-75?
